Hydraulic question
/ Hydraulic question #1
rmorgan
Summerside, OH
NH TC33D; RTV900; Gravely Professional
I finally bought the 3-point splitter I've thought about for awhile, and have a question about the hydraulic setup on my TC33D. The rear remote is controlled by a lever which returns to center (closed) after being moved either fore or aft. The splitter, of course, has its own hydraulic lever. The splitter is only powered when the lever on the tractor is open, at which point the splitter hydraulic control works normally. If I was to keep the remove open and control flow only on the splitter, would I be putting inappropriate stress on the system? And in the long run, what do I do to address this so's it works the way it should?
Thanks!
/ Hydraulic question #2
rmorgan - The manual that came with your splitter should identify the valve on the splitter as "open center" or "closed center". If it works properly when someone holds the tractor's remote valve open, the it's got to be "open center", so you can just bungee-cord the tractor lever into the on position or hold it open in some other way. Just remember to release it before you remove the splitter lines from the tractor. Alternatively, you would have to add another line with a needle-valve or something just for the splitter, which is more trouble than it's worth, I think.
Mark--
Thanks a lot!! The splitter actually came with parts to change the hydraulic innards, which I don't want to do (talks about vices, pressing out little parts, etc.) unless I have to . . . I didn't want to use the "bungee" word in my original post, but that is sure what I had in mind--just didn't want to blow anything up. Thanks so much!!
/ Hydraulic question #4
rmorgan - You're welcome! Never be embarassed about a productive use for a bungee cord. Some of my best ideas involved bungees. I'm not sure if that says more about bungees or more about my ideas, though... /w3tcompact/icons/laugh.gif
/ Hydraulic question #5
I've got this personal hangup about bungee cords; don't like them (maybe it's just that I figure anything that stretches that much may also break easily)./w3tcompact/icons/grin.gif However, I've seen some messages posted on that other forum by people who do exactly what Mark said, and under those circumstances, I probably would, too./w3tcompact/icons/wink.gif
/ Hydraulic question #6
Bird - I haven't had very good results with the cloth/elastic ones, but I love the rubber ones. Spray 'em with a UV-blocking rubber protectant and they'll last a long, long time, losing very little elasticity.
Bird--You'll probably recall from some of the early traffic on the TC's that they actually come with an "official" New Holland bungee cord to hold the hydraulic lines out of the way of the loader. (/w3tcompact/icons/blush.gif if you're a NH engineer) Who knows--maybe this new application will find its way into the next model year!!!!/w3tcompact/icons/laugh.gif/w3tcompact/icons/laugh.gif By the way--the TSC/Huskee splitter seems to work well (a bit slow, but that's as expected), and it comes with its own stand and works both horizontally and vertically.
/ Hydraulic question #8
Mark, I've had some poor luck with the cloth/elastic myself and think the rubber ones are better, but my brother has mentioned finding some tremendous price differences different places on the black rubber ones and we don't know if there's a difference in quality or whether it's just their pricing. However, I haven't worried about it too much, since I have exactly one black rubber bungee cord and it's used only inside the shop building./w3tcompact/icons/laugh.gif
/ Hydraulic question #9
Rick, I not only remember it, but have a cousin who has a TC29D and I was at his place when they delivered it. I couldn't believe that rinky-dink arrangement, and I think that alone would have kept me from buying a New Holland./w3tcompact/icons/wink.gif
/ Hydraulic question #10
Morgan,
Did the parts that came with your splitter give you the option of either making your splitter open or closed? Mine came this way. All mine was was changing the input on the splitter itself. I changed mine to open and ran it off of my open scv that I use for my backhoe and post pounder. This is alot easier than having to tie your hydraulics open all the time. If you don't have the open scv then mine also came with the materials to change the splitter to a closed system so that I could run it off of the normal scv. I'm pretty sure that's what the parts are for. Anyway that's the way mine was.
/ Hydraulic question #11
<font color=blue>...I've seen some messages posted on that other forum ...</font color=blue>
Bird... /w3tcompact/icons/laugh.gif... almost sounds like you're talking about a terrible disease or something... /w3tcompact/icons/smile.gif
{sorry... just my /w3tcompact/icons/crazy.gif sense of humor working overtime.../w3tcompact/icons/wink.gif}
2025 Precisions Provencal 22ft. 5th wheel Mobile Office/ Showroom Trailer (A64556)
2025 Precisions...
(INOP) 2013 MACK ELITE LEU633 GARBAGE TRUCK (A64280)
(INOP) 2013 MACK...
2018 Chevrolet Tahoe SUV (A66738)
2018 Chevrolet...
2012 CHANDLER TRI AXLE SPD-18 WATER HEATING TRAILER (A67714)
2012 CHANDLER TRI...
2025 Kioti CS2530 - like new!
2025 Kioti CS2530...
2006 UTILITY TRAILER MFG. CO. 48X102 SPREAD AXLE COMBO FLATBED (A67714)
2006 UTILITY...
