HYDRAULIC QUESTION
/ HYDRAULIC QUESTION #1
J_J
Super Star Member
JACKSONVILLE, FL
Power-Trac 1445, KUBOTA B-9200HST
IF YOU ADD TWO HYD PUMPS TOGETHER, SAY A MED OUTPUT PUMP, AND A LARGE HYDRAULIC PUMP, WILL THE GPM ADD UP, OR WILL THE LARGER PUMP OVER RIDE EVERTHING. I AM CONSIDERING THIS TO INCREASE THE OUTPUT OF THE PTO.?
J.J.
/ HYDRAULIC QUESTION #2
I don't know if you could have tandem pumps, both feeding into the same circuit. They might tend to work against each other. Might be better to get a larger pump.
