Hydraulic question?
/ Hydraulic question? #1
Heavyduty
What would happen if a hyd motor on a rotary mower, that was being powered by a pto driven 540 pump, was changed by being powered by a 1000 pto pump? :confused2:
/ Hydraulic question? #2
Nothing unless GPM delivery went up or down. In which case motor speed would change. -- If its the same pump you are turning faster it would near double [1000/540]
motor speed in comparison to the lower PTO speed.
larry
motor speed over the lower PTO speed.
larry
Thanks for the reply. I have two pieces of equipment, they are same but one is has a 540 pump driven by my tractors pto and the other has a 1000 pump. I was seeing if the motors could be swapped out if need be.:D
Gehl Mix-All 95 Grinder Mixer (A64047)
Gehl Mix-All 95...
Attention (A57148)
Attention (A57148)
2212CFL (A61572)
2212CFL (A61572)
2023 Kubota M7-174P (Premium) 4WD Tractor - 400 Hours (A63688)
2023 Kubota...
2025 Greatbear Rachet Tie Down & Flatpack Tool Box (A61567)
2025 Greatbear...
2005 JLG BOOM LIFT (A59228)
2005 JLG BOOM LIFT...
