Hydraulic question?
/ Hydraulic question? #1
Heavyduty
Gold Member
What would happen if a hyd motor on a rotary mower, that was being powered by a pto driven 540 pump, was changed by being powered by a 1000 pto pump? :confused2:
/ Hydraulic question? #2
Nothing unless GPM delivery went up or down. In which case motor speed would change. -- If its the same pump you are turning faster it would near double [1000/540]
motor speed in comparison to the lower PTO speed.
larry
motor speed over the lower PTO speed.
larry
Thanks for the reply. I have two pieces of equipment, they are same but one is has a 540 pump driven by my tractors pto and the other has a 1000 pump. I was seeing if the motors could be swapped out if need be.:D
2011 Freightliner B2 School Bus (A61568)
2011 Freightliner...
2018 FREIGHTLINER M2 106 S/A 4X2 26 FT BOX TRUCK (A59909)
2018 FREIGHTLINER...
DEUTZ MARATHON...
2001 Peterbilt 330 S/A Dump Truck (A60352)
2001 Peterbilt 330...
2016 Ford F-250 Service Truck (A61568)
2016 Ford F-250...
2461 (A58376)
2461 (A58376)
