Hydraulic Question
/ Hydraulic Question #1
Little Butch1
I have an L2800 Kubota and the hydraulics won't work.They were doing fine and I shut off the engine and now the bucket and mower won't work.I changed the filter,but still won't work.Any ideas ?thanks so much
Butch
/ Hydraulic Question #2
Welcome to TBN:D
Two things to check:
-That your rockshaft lever is centered (the lever that controls the 3PH)
-Unplug and re-seat any and all QD's (quick disconnects) on the hydraulic lines, especially if you have a backhoe plumbed.
Short of that, you will need to get a gauge and see if the pump is working.
Does the engine sound like it is under load? Any squealing noise?
Problem is solved.There was a cut in the hydraulic air return hose.We replaced the hose and everthing works great.I have heard this is a common problem on Kubota L2800 tractor.Thanks for your help KennyD.
/ Hydraulic Question #4
You are welcome, glad you got it fixed up:thumbsup:
2004 PROCO 130BBL VACUUM TRAILER (A65643)
2004 PROCO 130BBL...
(2) Firestone Tires (A65640)
(2) Firestone...
2010 Ford F750 Single Axle Dump (A62613)
2010 Ford F750...
2008 PROGRESSIVE 20' X 7' BUMPER PULL TRAILER (A65643)
2008 PROGRESSIVE...
500 GAL POLY FLAT BOTTOM TANK (A64277)
500 GAL POLY FLAT...
John Deere MX8 3-Pt 8' Rotary Mower (A66285)
John Deere MX8...
