Hydraulic pump weak
/ Hydraulic pump weak
An AMAZING coincidence since my old man died about 30 years ago. What's the site? I'd love to check that one out.:confused:
/ Hydraulic pump weak #62
Iron Horse said:
You may need to read my post again , i said 15w40 is for our HOT days in hydraulics not for the cold , as 10w loses it's viscosity when under extreme heat . And as ive posted before in other threads , 15w40 should only be used in warm climates as it is a little thick in extreme cold . But on worn machinery it can help to get a little more work out of it before it is rebuilt or scrapped . Now i said we use it for GEARBOX'S in cold weather as im sure your trucking guys also do because 90 becomes too thick and slows the gears in the box too quickly making gearshifts troublesome .
Your post said that you use 15w40 in EVERYTHING including the hydraulics because of problems on COLD mornings and you said that 15w40 should be left in the hydraulics year round. Once again I ask you: how cold does it get in Australia that you need to use 15w40 in the hydraulics? Maybe you should read your own posts before replying.
/ Hydraulic pump weak #63
I'll try to find it again.
/ Hydraulic pump weak #64
Oops, my bad. The post was by bigcountry1009 on TractorForum.com.
Please accept my apologies.:eek:
/ Hydraulic pump weak #65
Anyone have a spec sheet showing it is ok to use crankcase oil in an ep application? I'd get that in writing before i attempted it..
soundguy
/ Hydraulic pump weak #66
Iron Horse said:
Leave the 15-40 in it forever , there is nothing wrong with using it (and i did say if your sure it is worn out and just want to give it a little pep). We in Australia use it in everything , truck and tractor transmissions , engines , hydraulics and all , some manufacturers recomend it , ive never heard of a complaint . We would not be able to change gears with a 90 weight in our gearboxes on cold mornings so we all use 15-40 and on hot days 10w hydraulic oil losses it's viscosity so we use it in the hydraulics , Caterpillar dozers use it from one end to the other .
Post reads fine to me :confused: .
/ Hydraulic pump weak #68
Api rating for the engine is a bit dated.. but it is an example.
I have a feeling plain of fthe shelf 15w40 does not fit the bill, and this example you posted is a VERY specilized oil.
Just making the blanket statement to 'go change your UTF oil to 15w40 oil kinda falls short... as you would need that very special formulated oil that was rated to handle both crankcase and gear lube, and hyd applications...
soundguy
OK, it's time for a former technical lubricant guy to weigh in on this. It's been a bit more than 10 years, but unless additive packages have improved dramatically, here' my take.
1. 15w/40 is used in many hydraulic applications, including multi-million dollar Caterpillar loaders, haul-trucks and the like.
2. Transmissions in large equipment have also been using 15w/40 for many years.
3. 80w/90 gear oil, like Shell's Spirax are the best bet for differentials. I never recommended 15w/40 in these applications.
4. If you have lotsa money to spare, in cold climates, ATF or aircraft hydraulic fluids are excellent for hydraulics.
No bigge!:D
/ Hydraulic pump weak #72
Iron Horse said:
I think i could have pasted a dozen links from every manufacturer with the same result :rolleyes: .
Perhaps. But I don't think many of them would describe products actually sold across the counter here in the USA. What you've posted so far sounds like what's sold in this country as UTF (universal tractor fluid).
So what I think is happening here - is that you're using (and referencing) products manufactured to ISO standards. While we here in America are on the SAE standard
//greg//
/ Hydraulic pump weak #74
You're only continuing to make my point for me. That was a British brochure. Are you having trouble finding and American one?
//greg//
/ Hydraulic pump weak #75
You can't possibly be serious . Are you saying that if you get the "special" British John Deere oil it would be a different story and be OK . Or should everyone buy British sold John Deere tractors so they can use the "special" British advertised 15w40 oil . I never knew that a John Deere tractor sold in the USA could not use the same oil as one sold in Britain . I wonder were the oil actually comes from or where it is made . There were 2650 sites that Google found relating to 15w40 gearboxes . Like i said before i could post a dozen of them and it would make no difference to you . I'm outta here .
/ Hydraulic pump weak #76
Bye, and glad you are out of here. This discussion was about hydraulics, not gearboxes. You still have not answered my question about how cold it gets down under. G'day mate.
bluechip said:
The 306 pump is the basic pump used on tractors without front loaders. it is around 3gpm and will be slow under the best of conditions. We stock a 314 replacement that will speed things up, more than doubling the flow rate. This of course does not take into account any potential restriction in the system (often caused by mismatched quick connect fittings, etc).
I got the 314 and it's like a brand new machine. Holy cow, I can get the front end off the ground and don't even have to rev the engine to raise a FULL bucket of dirt.:cool:
/ Hydraulic pump weak #79
Did you take the other one apart and look for seal damage? And the Seals shaped like a W? O-rings?
I took it from the way you descibed that at one time it worked better than it was.
Not yet.
2015 Ram 1500 Pickup Truck (A64556)
2015 Ram 1500...
2016 Ford Escape SUV (A64557)
2016 Ford Escape...
2018 Ver-Mac S/A Solar Towable Speed Trailer (A64194)
2018 Ver-Mac S/A...
2009 MAC 35ft. 75yd. Tri-Axle Aluminum End Dump Trailer (A64556)
2009 MAC 35ft...
2015 International WorkStar 7500 T/A Forestry Grapple Truck (A64556)
2015 International...
2014 CASE CX160C EXCAVATOR (A65053)
2014 CASE CX160C...
