SPYDERLK
Super Star Member
- Joined
- Feb 28, 2006
- Messages
- 12,625
- Location
- VA
- Tractor
- JD2010, Kubota3450,2550, Mahindra 7520 w FEL w Skid Steer QC w/Tilt Tatch, & BH, BX1500
If the pump is deadheading you will blow the new pump, or a hose, if the engine starts. Expensive and/or dangerous experiment. Pressure must have a relief point. Get a hyd mechanic to check it out. You may have an extremely restricted/plugged line caused by an internal failure of a hose liner. If this hose is before the system relief valve it would have either blown the pump [one mode of which could cause the pump to bypass internally as would account for your heat in the existing pump], or blown the hose. Obviously the hose didnt blow.DwayneB said:If the pump is dead heading at startup you are going to have a hard time starting the tractor with the added load.
larry
