woodlandfarms
Super Member
- Joined
- Jul 31, 2006
- Messages
- 6,155
- Location
- Los Angeles / SW Washington
- Tractor
- PowerTrac 1850, Kubota RTV x900
So, I am designing a couple of attachments and I have an idea, but with any good idea, it may be a bad idea.
First, my tractor is all hydraulic. I want to power a couple of PTO style implements. So there are some expensive adapters out there I have considered, but at $4K at 500lbs, it is not going to work for me.
So, in an effort to save money, I am mulling over one hydraulic pto motor and swapping it between implements (Post hole digger and stump grinder for the moment).
So, to my structural issue.... Basically, instead of mounting the motor to a plate, and welding that plate somehow in line with the implement, and putting a collar between the two (motor and implement) I was thinking about "hanging" the motor with a chain. The collar would keep it all lined up, the chain would keep it from spinning.
Downsides I can think of, but may not be an issue (Like I said I saw this rig somewhere else) is that it there will be too much stress on the bearings of the motor or the implement, that there is no "Give" using a solid coupler between the two (it is how other hydraulic PTO adapters work). And maybe just too much stress for a chain when the implement comes to a sudden stop.
So, thoughts?
So, thoughts?
