Hydraulic PSI (for implement) on CK35
/ Hydraulic PSI (for implement) on CK35 #1
rjpotts
Bronze Member
Kioti CK3510SEHC
Anyone know what the max PSI is for hydraulic output on a CK35? I'm planning to build an implement that will use hydraulic pressure from one of the rear ports, to size the cylinder bore correctly I need to know what PSI I'm dealing with. I looked in the owners manual but it only specifies volume, not PSI.
/ Hydraulic PSI (for implement) on CK35 #3
It's not that expensive to get a hydraulic gauge and QD end, plug it into your port and find out. Then you'll have a test tool :}
2018 KAUFMAN GOOSENECK TRAILER (A63290)
2018 KAUFMAN...
x (A68191)
x (A68191)
BODY LOAD TANK (A67714)
BODY LOAD TANK...
100 GALLON FUEL TANK/ FUEL NOZZLE (A68842)
100 GALLON FUEL...
2009 POLAR TANK TRAILER (A67714)
2009 POLAR TANK...
Bainbridge,Georgia (A65640)
Bainbridge,Georgia...
