3-Point Hitch hydraulic problems on 2030
/ hydraulic problems on 2030 #1
ARno1
north dakota
john deere 2030
My three point will raise VERY slowly. If I run the loader at the same time the three point will raise normal. I have a JD 2030 with independant PTO the shaft between the shifter and no reverser or shift transmission. It is standard 8 speed forward 4 reverse. The previous owner also said the 3 point would stall in heavy grass. I just bought the tractor and do not know the condition of the PTO. Thanks
/ hydraulic problems on 2030 #2
:welcome:
Not sure of what the problem might be.
I don't understand what is taking place when you said "the 3 point would stall in heavy grass" ??
A little more discussion and maybe we can figure it out.
/ hydraulic problems on 2030 #3
Welcome to TBN, ARno1. So, it's a standard collar shift tranny; no reverser and no rabbit/turtle, either.
The pto engagement is located between the transmission shift levers at the base of the steering column, right?
If I understand your other problem(s); the pto doesn't always work as the the engine will stall (or the pto will stall - clutch slips) in heavy grass when mowing -- is that correct?
And the 3pt lift doesn't always work as it should, either? The lift arms won't always raise or you have to engage the front loader to get the 3pt arms to raise -- is that one of the problems, too?
AKfish
/ hydraulic problems on 2030 #4
3pt slowness in raising is caused from a leaking loader control valve(operating loader valve temporarily blocks leakage). If loader control valve is an ind spool valve I'd suspect it's either an open-center valve or a valve with a blown o-ring that converts it to closed center. Remove loader valve return hose from tractor,crank engine with both valve levers in neutral and if oil flows out return hose you've found one problem. If pto slows down with mower in tall grass then ind pto clutch is slipping. Check clutch psi(165) on trans top cover under metal cover gearshift levers protrude through.
I have only been told about the PTO problem and have not had any equipment hooked up to it to experience the problem first hand. I mentioned the problem in case it could be related to my three point raising slowly (until I use the loader). I was told that when the pto stalls it has no affect on engine RPM. AKFISH all of your assumptions are correct. I will test the loader control valve and clutch PSI as Tx Jim suggests. I am in Texas this week and will work on the tractor next week. I GREATLY appreciate the help and I will let you know what I find. I have heard of cracked lines to the PTO clutch. If PSI is ok, what is most likely suspect and if PSI is low what would be most likely? Thanks again.
/ hydraulic problems on 2030 #6
If pressure is OK, then the cllutch disks are probably worn out. If pressure is low, The a cracked oil line, clutch piston seals, or sealing rings on clutch drum are probably worn.
One other item to consider on the three point hitch, a couple of times I have seen a weak spring on the linkage under rockshaft housing to be the cause. The spring(#1) needs enough tension to pull open the pressure(raise) valve.
I appreciate the help what is the best way to test the spring pressure.
/ hydraulic problems on 2030 #8
My 2030 has the independent PTO. The line to the clutch pack cracked. When the PTO was engaged, no other hydraulics would work, all flow was going to sump from the broken line. Turn the PTO off and hydraulics worked. I had to split the tractor to repair :(
/ hydraulic problems on 2030 #9
To test the spring in the photo the rockshaft housing will require to be removed. I suggest testing loader valve first as that's much easier.
I unhooked my loader hydraulics and the three point functioned properly. Now, my question is if the spool valve is serviceable or not? I could not test the pto, because the only pto implement I have is a snowblower. Could the bad spool valve cause low hyd pressure at the PTO clutch?
/ hydraulic problems on 2030 #11
Pto is operated off of trans pump psi while loader is operated off of main high pressure ft pump. Loader valve if the convertible type(open to closed/vice-verse) could have a blown internal(replaceable) o-ring(parts key #10). Technically the o-ring mentioned above and spool seals is all that's repairable on a spool valve.
/ hydraulic problems on 2030 #12
hi everyone looking for some advise please i have a john deere 2030 i was out topping yesterday when i picked up a tarpolen around one of the blades on the topper and the topper stopped so i thought the shear pin on the pto shaft sheared when i checked the pin it was fine so i stopped the tractor checked things over and all seemed ok started the tractor up lifted up the back arms all ok but still no pto working so i headed back for home on my way back about half a mile down the road i lost powersteering got back home lowered the topper down with the back arms and now cant lift the arms up i have lost all hydraulics no pto working no back arms and no steering any ideas thanks paul
/ hydraulic problems on 2030 #13
Check frt hyd pump coupler for stripping. How long since hyd filter was changed and sump screen checked/cleaned? Which type pto continuous running(dual stage foot clutch) or hyd ind pto??
/ hydraulic problems on 2030 #14
Hi thanks for reply the coupler is fine not sure when filter was changed not sure where it is and sump screen check not sure what this is? And the pto is controlled from a leaver just underneath the steering wheel on the right hand side next to the hand throttle.
/ hydraulic problems on 2030 #15
Are you 100% sure that main hyd pump shaft is turning with the engine crankshaft?? The couplers have a history of spinning on the pump shaft.Sounds as if pto is the hyd ind type. Screen(parts key #30) is accessed on RH side by hyd filter
/ hydraulic problems on 2030 #16
Any ideas where the hydraulic filter is on this tractor ??
/ hydraulic problems on 2030 #17
Pump 100% turning with crankshaft checked oil filter spotless took the screen out was nice and clean apart from the last inch or so of the screen a fair bit of crap come out would this be enough to give me problems ? Thanks
/ hydraulic problems on 2030 #18
Loader control valve could be leaking internally. Does loader have an independent hyd valve or is it controlled by tractor remote valves(SCV's)??
/ hydraulic problems on 2030 #19
Which is the loader valve please? I cracked open the 3 hoses into the front hydraulic pump the top inlet had oil the discharge port had oil but the right inlet had nothing what so ever dose this info help?
/ hydraulic problems on 2030 #20
It's been since the late 80's since I worked for a JD dealer but IIRC line #1 carries trans pump oil to frt hyd pump and line #13 carries high pressure oil to the rear. Ind loader valve would be attached to loader on RH side.
