Hydraulic problem
/ Hydraulic problem #1
bcarpenter
John Deere 870
My hydraulic fluid was low the hydraulics were slow and I put in a 20w oil and now nothing works.
/ Hydraulic problem #2
what weight does your tractor call for?
may need low viscosity 5w
/ Hydraulic problem
It calls for low viscosity hygard oil
/ Hydraulic problem #4
The heavier 20W may not be getting through the filter. The hydraulic filter is a suction affair. Between the heavy weight and the colder temperatures, you may be cavitating the hydraulic pump.
I would suggest draining the whole mess and starting over with the correct hydraulic oil. Replacing the hydraulic filter is also part of starting over.
Then if everything works again .. determine where the hydraulic fluid went in the first place. It's a closed system. Only leaks make for low fluid levels.
/ Hydraulic problem
I have the front end loader handle tied back and when I crank it up the loader will raise about 4 foot and then eventually fall back to the ground. I can leave it running and still nothing happens.
/ Hydraulic problem #6
So you put 20 weight engine oil into your hydraulic system ?
Hopefully the pump hasn’t been ruined ! That would be very expensive to replace .
/ Hydraulic problem
It’s a 20w hydraulic oil
/ Hydraulic problem #8
The data sheet for low viscosity hygard shows it is 7.4cSt @ 100C which converts to SAE 19.9W oil, and it's 33cSt @ 40C which is about SAE 11W oil. So the engine oil you used is a bit too thick at low temps but is right on the money once the oil gets hot. So I'm not sure the oil you used caused the problem, I think you had a problem to start with that may have been caused by running with too little oil. You say in the OP that the hydraulic fluid was low and the actuation was slow. How much oil did you add and how much does the system hold?
/ Hydraulic problem
Thanks for your help. I will clean it out and change the oil would you happen to know how many gallons it holds
/ Hydraulic problem
I only added a gallon to gallon and a half. I think it holds 9 gallons
/ Hydraulic problem #11
Tractordata.com says it holds 5.5gal. Do you have quick disconnects on your loader? If you do, sometimes if one isn't really connected it can cause a problem like this. I'd try disconnecting and reconnecting all the quick disconnects and make sure they feel like they're properly seated.
/ Hydraulic problem #12
Did you get this resolved?
Is this just the loader being slow or is the 3PH slow and not working either?
/ Hydraulic problem #13
I have a MF 205-4. The service manual calls for 80W for the rear end/hydraulics... I was like like WHAAAAT? Here in the north east that wont work so well in the winter months lol. I talked to some hydraulic pros and they told me just use a standard generic hydraulic oil and I will be fine
2013 Ford F-350 4x4 Crew Cab Knapheide Service Truck (A61573)
2013 Ford F-350...
2013 Mack CXU613 T/A Day Cab Truck Tractor (A61573)
2013 Mack CXU613...
2022 ASV RT-25 Posi-Track Compact Track Loader Skid Steer (A61572)
2022 ASV RT-25...
2019 JOHN DEERE 333G SKID STEER (A64279)
2019 JOHN DEERE...
2015 Freightliner M2 106 AWD Altec AT37G Bucket Truck (A60460)
2015 Freightliner...
2007 Sterling L9500 Fuel & Lube Y22693 (A62613)
2007 Sterling...
