Hydraulic problem
/ Hydraulic problem #1
Degolyerent
I have a MX4700 DT it has 370 hours it just started making a hydraulic bypass type noise when I lift the three point hitch all the way to the top
The noise is the same as when you lift your FEL to the top and don't release the lever
I had a new hydraulic filter so I put it on immediately but it still makes same noise
The tractor is still under warranty but I am curious as to what the problem may be
It calls for hydraulic oil change at 400 hours
/ Hydraulic problem #2
When you raise the 3pt to the max, the relief will go off and make a sound. That is normal.
The fluid through the system has to go somewhere, with the piston at max lift.
/ Hydraulic problem #3
If you set the lever just short of max height it doesnt bypass, right? It sounds like youre calling for a higher position than the 3ph can mechanically reach. My 2 Kubs with position control have an adjustable stop at the top portion of the control lever travel to allow setting it to stop short of calling for a height that hits the internal mechanical limit of the rocker shaft.
larry
/ Hydraulic problem
Thanks, something has happened with the adjustable stop I guess, it must be visible from under side of tractor. I did not realize that it has a adjustable stop for the up position. I know it has the adjustable knob to stop it in the down position
/ Hydraulic problem #5
Check your feed back lever adjustment. See if the nut have backed out.
/ Hydraulic problem
I will check that out when I have a chance again, I posted last night without looking at tractor and as far as the upper stop goes it is in same position as always, so I will check to see if nut on lever has backed out, I appreciate your help with this situation
Thanks again, TBN rules!
/ Hydraulic problem #7
Try not going quite all the way to the stop. Does it still do it?? We have ours set pretty critical at the limit and it does it sometimes if we just slap the lever all the way up. It may not be the same as your issue, but sounds like.
larry
/ Hydraulic problem
The upper stop is not adjustable, and if I stop short of it it does not make the noise, I put a bolt in front of the stop to give it something to 'stop' to
What I don't understand is what could have changed, everything is tight as far as the lever goes, all seems well otherwise
With my new stop in place it does not make the noise and it goes very close to all the way up
/ Hydraulic problem #9
If you installed a hyd gage in the system, you can monitor the pressure, and use the gage to trouble shoot your system. It would tell you exactly if any valve is in relief, and allow you to set the PRV when necessary. .
/ Hydraulic problem #10
Degolyerent
The lever you move up and down is noi what I'm talking about. It's called a feed back lever, look on the left side of the main lift arms (some have them on the right but yours should be on the left) and you well see a lever and rod with a adjusting nut and jam nut. See if everything is ok there. You should be able to ajust and the arms max out the same time the hand lever hits it stop.
/ Hydraulic problem
Leejohn said:
Degolyerent
I found it and gave it a very slight adjustment and everything is fine now! Thanks very much
John
/ Hydraulic problem #12
Good to hear it fixed it without going into alot of other stuff. Lee
2015 ISUZU NQR 4X2 DEBRIS TRUCK (A59911)
2015 ISUZU NQR 4X2...
EZ-GO GAS GOLF CART (A63276)
EZ-GO GAS GOLF...
2011 Nissan Juke AWD SUV (A61574)
2011 Nissan Juke...
AUCTION STARTS HERE @ 9AM (A63276)
AUCTION STARTS...
2018 Ford Focus Sedan (A61574)
2018 Ford Focus...
2025 Swict 72in Bucket Skid Steer Attachment (A61572)
2025 Swict 72in...
