Hydraulic problem TS4510
/ Hydraulic problem TS4510 #1
edinaus
I recently bought an Iseki TS4510 which has power steer.
The problem is that the 3pl will not lift any weight and the power steering has no hydraulic power. The hydraulic lift, will lift with no implement attached but only when the motor is operating at about 2000 rpm. The power steer does not appear to work at any time.
I have renewed the spin on type hydraulic oil filter and hydraulic oil with correct types. I have pulled the hydraulic pump off and had it checked - no problems there. There appears to be a valve body before the power steer, is this a usual place for problems?
Any other problem identification hints would be appreciated. Thanks, Ed.
/ Hydraulic problem TS4510 #2
Hi Ed,
I have the same model and exactly the same problem and it remains a mystery to me did you discover the cause ?
/ Hydraulic problem TS4510 #3
First thing I would do is check the hydraulic pressure. It should be around 2000psi at high rpm.
UNUSED PARBREAK SBT280 HYD STUMP GRAPPLE BUCKET (A65055)
UNUSED PARBREAK...
Honda EM 7000is Inverter Generator (A64553)
Honda EM 7000is...
JOHN DEERE 5055E TRACTOR (A65054)
JOHN DEERE 5055E...
2016 Volvo XC60 SUV (A64557)
2016 Volvo XC60...
2017 Ford F-150 4x4 Pickup Truck (A64556)
2017 Ford F-150...
2003 PETERBILT 379 SLEEPER (A59914)
2003 PETERBILT 379...
