Hydraulic problem TS4510
/ Hydraulic problem TS4510 #1
edinaus
I recently bought an Iseki TS4510 which has power steer.
The problem is that the 3pl will not lift any weight and the power steering has no hydraulic power. The hydraulic lift, will lift with no implement attached but only when the motor is operating at about 2000 rpm. The power steer does not appear to work at any time.
I have renewed the spin on type hydraulic oil filter and hydraulic oil with correct types. I have pulled the hydraulic pump off and had it checked - no problems there. There appears to be a valve body before the power steer, is this a usual place for problems?
Any other problem identification hints would be appreciated. Thanks, Ed.
/ Hydraulic problem TS4510 #2
Hi Ed,
I have the same model and exactly the same problem and it remains a mystery to me did you discover the cause ?
/ Hydraulic problem TS4510 #3
First thing I would do is check the hydraulic pressure. It should be around 2000psi at high rpm.
John Deere 5220 53HP Loader Utility Tractor (A64194)
John Deere 5220...
SHOPBUILT S/A TRAILER (A64278)
SHOPBUILT S/A...
17in. Bucket w/ Teeth Excavator Attachment (A64194)
17in. Bucket w/...
46185SFL (A64557)
46185SFL (A64557)
Used Landpride GR1525 Stump Grinder
Used Landpride...
Kivel 42in Forks and Frame Mini Skid Steer Attachment (A64553)
Kivel 42in Forks...
