hydraulic pressure test kit
/ hydraulic pressure test kit #1
mad_planter
I'm looking at picking up a test kit for my Ford 250C. The power steering isn't what it should be and the pto doesn't work properly and I need it to diagnose the issues. What kit and or Fitting would be recommended for these series tractors (tractor is a 94)? Hoping to stay at or around $100.
Thanks all!
/ hydraulic pressure test kit #2
I don't know your tractor, but doesn't the PTO run directly off the gearbox? No hydraulics.
As for the PS, the simplest way to go is to get a 3000-5000 psi gauge ($20), and the fittings
necessary to connect it to the end of one PS hose. Then disconnect the hose with
the steering turned to the end of its travel. Start the tractor and try steering in that
same direction. There are 2 ways to do this, so do it the the correct way.
If you did lots of tests, then plumbing a TEE fitting between the hose and cyl would
be a better, but a more expensive way to go.
John Deere S350 (A60462)
John Deere S350...
2012 INTERNATIONAL 4300 4X2 26FT NON CDL BOX TRUCK (A59911)
2012 INTERNATIONAL...
2013 Ford F550 Bucket Truck w/ Jib (A62613)
2013 Ford F550...
2019 HYUNDAI V12530152-AJS 53' X 102" T/A VAN TRAILER (A59910)
2019 HYUNDAI...
2016 CATERPILLAR 308E2 CR EXCAVATOR (A64279)
2016 CATERPILLAR...
APPROX. 2000 GALLON FUEL TANK (A63291)
APPROX. 2000...
