Hydraulic plumbing Q?
   / Hydraulic plumbing Q? #1
uncaged
southern VT
Kubota BX23
I'm trying to figure out how to pull some hydraulics off a dead forklift to use on my Kubota with rear remotes and was hoping I could get some help in understanding how it's plumbed. I've attached a sketch of how it's plumbed, for a visual.
The forklift has a valve that raises the mast, and another valve that angles the mast, both are Parker VDP valves. The angle valve looks to be like a normal DA cylinder valve. The mast valve is a little funky. Well, first, there is what looks to be 2 pumps running piggyback off the same shaft. A small pump and a big pump. The "out" of the small pump runs to the angle valve and the "out" of the big pump runs to the mast valve.
One thing I don't understand, is that a line runs from the angle valve to the mast valve. Why is this? Why wouldn't it return to the tank? The mast valve already has a pressure line running to it.
What is the reasoning behind the 2 pumps running 2 separate lines to each of the valves?
How would I plumb this to run from one supply line?
How much pressure is on the line that comes out of the mast valve and goes to the filter? It can't be much, and where did the pressure go that was supplying the valve?
Sorry for so many questions, I'm soaking up as much as I can as fast as I can. :D
Thanks!
  • forkliftschematic.pdf
OK, found more info that may help. It looks like on the mast valve, next to the fitting that runs to the angle valve, it has a CO cast into the mast valve. Could this be Carry Over, as in High Pressure Carry Over, as in power beyond? If this is the case, still, what's the deal with a pressure line coming from the mast valve to the angle valve, and then the other line to the angle valve running to a pump?
Hmm? :rolleyes:
   / Hydraulic plumbing Q? #3
Only a guess. Perhaps the small pump runs the tilt cyls. (low flow = better control) and the large pump the mast cyl. with the small pump adding flow for a faster lift.
ron
   / Hydraulic plumbing Q? #4
I don't have much time right now, I'll answer more completely later.
Mast raise is a high pressure application, single acting cylinder. Tilt is a low pressure application. Probably also runs the steering circuit. Line from the tilt valve to the lift valve is for return to tank. When run together, takes less parts, therefore, less money.
WCH, I eagerly await your response to the first questions :D
The lift valve has a tag that says it is a Parker VDP 11 P 34 (and at the end of that line is a hand stamped H) which according to the literature, says it's an open center, single acting spool with only B port used. The H means it has a power beyond sleeve.
It makes sense what you said about return from the angle valve, but would the lift valve have a power beyond sleeve in the return port?
Thanks for your help,
Mike
   / Hydraulic plumbing Q? #6
Mike
I don't know what the Parker #'s mean, but I do know how they configured these valves. They only use one work port for lift, in your case, B port. This is because they only have one line running to the lift cylinder. It's a single acting cylinder, power up, gravity down. The A port gets capped. See next post.
   / Hydraulic plumbing Q? #7
They do this to save costs on plumbing. If they all go back to tank anyway, the earlier they can do it, the less hose they use, the more money they save.
They run 2 different pressures, one high pressure for the mast lift, (about 2250 psi) one low pressure for mast tilt, steering, and any other hyd accessories. (about 1100 psi)
The same way you would plumb anything else.
Between the mast lift valve and tank, there isn't much pressure. Where did the pressure go? It was reduced by flowing thru a larger line which has less restriction, therefore, lowering the working pressure. General rule of thumb, for hose sizes, is suction line is 2x the pressure line i.d. Return line is 1.5x the pressure line i.d.
Don't be afraid to ask, none of us were born experts.
Forklifts generally have very high quality hydraulic components. Anything you can use off a forklift should do the job for you.
Great information!
The lift cylinder is single acting, but has a hose that comes out of the top of it, with nothing more than a hose clamp holding it on. Does anything come out of that and at what pressure? Can that hose be Tee'd into the return to the tractor or should it have its own direct return to tank separate from the valve returns, or atmospheric vent, or...?
So, for plumbing the valves, I'm thinking that pressure from the tractor should go to the lift valve first, make sure a PB sleeve is in there, then continue it from the PB port to the angle valve (my new TnT valve!) pressure port. Tee each of the valve's returns together, back to the tractor. Am I getting close?
   / Hydraulic plumbing Q? #9
The lift cylinder is single acting, but has a hose that comes out of the top of it, with nothing more than a hose clamp holding it on. Does anything come out of that and at what pressure? Can that hose be Tee'd into the return to the tractor or should it have its own direct return to tank separate from the valve returns, or atmospheric vent, or...?[/QUOTE]
The hose coming out the top of the cylinder is a dump back to tank. It's there for 2 reasons.
1. To provide a vent for clean air. Being a single acting cylinder, when the cylinder extends and contracts, it pushes out and pulls in air. This hose goes to the tank and is pulling in air from the tank that already went thru a breather assembly.
2. When the cylinder seals leak, instead of spilling oil on the cylinder and floor, the hose carries the fluid back to tank.
A real easy way to see if this style cylinder is leaking is to put a load on it and disconnect the small hose from the tank. If there is fluid flow, the seals are leaking. This fluid flow would be the fluid bypassing the seals.
There should be very minimal pressure at most thru this line.
Do not Tee into this line or do anything else to it. Just let it do it's job.
So, for plumbing the valves, I'm thinking that pressure from the tractor should go to the lift valve first, make sure a PB sleeve is in there, then continue it from the PB port to the angle valve (my new TnT valve!) pressure port. Tee each of the valve's returns together, back to the tractor. Am I getting close?[/QUOTE]
Sounds like you are on the right track.
Just wanted to say thanks for all your help. The forklift project was a success.
   / Hydraulic plumbing Q? #11
Looks like you did a great job. I'm jealous, I have all this knowledge, can get all the parts for nothing, and I never did this. I guess I just proved that I'm a lazy idiot.
Glad everything worked out. Just one caution, if you are doing anything with any kind of weight at all, put a nice load in the bucket for counterweight. If you look at a propane lumberyard type forklift, the entire piece on the back under the propane tank is one huge piece of cast steel. The small counterweights weigh about 1.5 tons. Please, be safe, put a load in the bucket regardless. I don't want to see you post a picture of your tractor laying back on the mast with the bucket pointing straight up in the air.
   / Hydraulic plumbing Q? #12
Now that's ingenious. Leave it up to TBN members to find new uses for their tractors.
Thanks. While pilfering the hydraulics out of the forklift, I did remove two good sized cast weights that I've already chained together at their former mount points to use as counterweights.
I'm so ingenious I'm borderline nutcase :D
2012 MACK Tender Truck w/ADAMS Rear Discharge Bed Auger (A61307)
2012 MACK Tender...
Crown RM6025-45 4,500 LB Stand-On Electric Forklift (A59228)
Crown RM6025-45...
2015 FREIGHTLINER M2 26FT CDL REQUIRED BOX TRUCK (A59905)
2015 FREIGHTLINER...
2009 MULTIQUIP 25KW GENERATOR (A55745)
2009 MULTIQUIP...
2012 DIAMOND T TRAILER TRAILER (A58214)
2012 DIAMOND T...
CAT 777B ARTICULATED DUMP TRUCK (A58214)
CAT 777B...
