hydraulic oil
/ hydraulic oil #7
I just bought it from the JD dealer, and believe it or not, it was cheaper than TSC.
/ hydraulic oil #8
I bet that it is JD303 compatible. They even "borrowed" JD's number but, I would ask the dealer to confirm that before I put it in my tractor.
/ hydraulic oil #9
"IS AcceL 303 Tractor HydrauLic Transmission Fluid the same as JD-303."
I'm sure it's the same, and I'll bet it says in small print. Every autoparts store, or Walmart, carries JD303 hy/tran equivalent, in many different brands, a lot cheaper than any tractor supply place.
/ hydraulic oil
I was getting it at TSC for $25 for 5gal. And it said JD-303 ,But they did not have the one i have been getting this time.
/ hydraulic oil
I was getting it at TSC for $25 for 5gal. And it said JD-303 ,But they did not have the one i have been getting this time. I look good and did not see JD on it .
/ hydraulic oil #12
what about chevron machine oil aw? that what my mahindra 4500 takes, im wondering if i can put it in a ym165 transmission. i have a 5 gallon bucket.
/ hydraulic oil #13
Check it's compatibility specs. if it lists stuff like JD 303 or similar oils.. CNH 134d.. etc.. then it's a generic 'UTF' oil and should be ok.
Soundguy
/ hydraulic oil
I got it at autozone for $30 and it has JD303 on it .JD wanted $50 for there's I would still like to know if AcceL 303 Tractor HydrauLic Transmission Fluid is the same.it don't said JD303 any were on it we look real good.
/ hydraulic oil #15
Does it list any other oils that might be 303 equivalent... like CNH 134d.. etc?
Soundguy
/ hydraulic oil #17
Check with the manufacturer and ask for a spec sheet for it. Otherwise.. I'd donate that oil to the waste drum and get some oil that listed what it actually was..
Soundguy
2021 CATERPILLAR 420XE HRC BACKHOE (A65053)
2021 CATERPILLAR...
GENERAC MOBILE PRODUCTS MAGNUM LIGHT/WATER PLANT (A67714)
GENERAC MOBILE...
213087 (A64276)
213087 (A64276)
1989 CUTOM 15T-100 EQUIPMENT TRAILER (A66091)
1989 CUTOM 15T-100...
Tow arm attachment (A64194)
Tow arm attachment...
2015 KENWORTH T680 (A67714)
2015 KENWORTH T680...
