hydraulic oil
/ hydraulic oil #7
I just bought it from the JD dealer, and believe it or not, it was cheaper than TSC.
/ hydraulic oil #8
I bet that it is JD303 compatible. They even "borrowed" JD's number but, I would ask the dealer to confirm that before I put it in my tractor.
/ hydraulic oil #9
"IS AcceL 303 Tractor HydrauLic Transmission Fluid the same as JD-303."
I'm sure it's the same, and I'll bet it says in small print. Every autoparts store, or Walmart, carries JD303 hy/tran equivalent, in many different brands, a lot cheaper than any tractor supply place.
/ hydraulic oil
I was getting it at TSC for $25 for 5gal. And it said JD-303 ,But they did not have the one i have been getting this time.
/ hydraulic oil
I was getting it at TSC for $25 for 5gal. And it said JD-303 ,But they did not have the one i have been getting this time. I look good and did not see JD on it .
/ hydraulic oil #12
what about chevron machine oil aw? that what my mahindra 4500 takes, im wondering if i can put it in a ym165 transmission. i have a 5 gallon bucket.
/ hydraulic oil #13
Check it's compatibility specs. if it lists stuff like JD 303 or similar oils.. CNH 134d.. etc.. then it's a generic 'UTF' oil and should be ok.
Soundguy
/ hydraulic oil
I got it at autozone for $30 and it has JD303 on it .JD wanted $50 for there's I would still like to know if AcceL 303 Tractor HydrauLic Transmission Fluid is the same.it don't said JD303 any were on it we look real good.
/ hydraulic oil #15
Does it list any other oils that might be 303 equivalent... like CNH 134d.. etc?
Soundguy
/ hydraulic oil #17
Check with the manufacturer and ask for a spec sheet for it. Otherwise.. I'd donate that oil to the waste drum and get some oil that listed what it actually was..
Soundguy
2011 FORD F-750 CHEMICAL TRANSPORT TRUCK (A65643)
2011 FORD F-750...
Wolverine RPR-12-72W Skid Steer Ripper  (A62679)
Wolverine...
3098 (A63117)
3098 (A63117)
4021 (A59228)
4021 (A59228)
2024 Ford Transit Box Van, VIN # 1FDRU6ZG8RKB10273 (A65563)
2024 Ford Transit...
Cattle Feeder (A65640)
