hydraulic oil ???????
/ hydraulic oil ??????? #1
whitearrow
philadelphia,ms
john deere 5203
hello all,i have a ? involving the hydraulic fluid in my tractor.i have a new jd 5203 and can't seem to find out how to check the power steering fluid.is the power steering fluid and hydraulic fluid the same thing?i guess what i am asking is if you have plenty hydraulic fluid on the dipstick then you are ok with your power steering too?i searched the owner's manual and couldn't find anything on the power steering system.
thanks for your time,
whitearrow->>>--------------->
/ hydraulic oil ??????? #2
The power steering fluid for most tractors, use the same oil as the transmission. When you check the trans oil you are also checking the power steering oil level.
/ hydraulic oil ??????? #3
Can't speak for the 5203, but on my 4600 it is the same fluid for both.
-Bob
KBH Tank Trailer (A63118)
KBH Tank Trailer...
1995 Ford F-250  7.3L Powerstroke Diesel (2WD, Long Bed) (A63118)
1995 Ford F-250...
2021 KUBOTA SVL95-2S SKID STEER (A62129)
2021 KUBOTA...
FLATBED SEMI TRAILER (A61568)
FLATBED SEMI...
2017 Chevrolet Cruze Sedan (A61569)
2017 Chevrolet...
2005 PETERBILT 379 TRI AXLE  DUMP TRUCK (A59575)
2005 PETERBILT 379...
