HYDRAULIC oil
/ HYDRAULIC oil #1
GBT206
LONG RISTON
YANMAR 186D
Hi
Proplem with 186d yanmar tractor purchased dec:2014. hydraulic oil going into sump of engine fitted new oil seal in hydraulic pump twice second time fitted sleeve on shaft oil still went into engine sump found air line crack in pump housing. have bought new alloy pump but not fitted as yet I need to no were the pressure relive valve is on tractor so i can correct the pressure. apart from that the tractor is going to be a good little work horse I hope.
I have also fitted new oil and hydraulic filters do not no if there are any more filters like a mesh filter in output unit?
can you help please
G
ps no manuel as yet
/ HYDRAULIC oil #2
:welcome:
To the forum from Northwest Alabama. Are you located in Louisiana? I can't help as never had that tractor but I am sure some of the Yanmar owners can.
/ HYDRAULIC oil
Hello and thank you for getting back to me
I am not located in Louisiana I'm in the UK lived and worked in London for 40years and lived on a large boat on the Thames have now retired and move north
G
/ HYDRAULIC oil #4
Hi, GB. I was in London once, many years ago while in the Air Force.
/ HYDRAULIC oil #5
I sent you a private message, if you will respond to it I will share something that could help you.
Your control valve is underneath the cover that your three point lever goes through. the relief valve for the 3 point is in that control valve. I doubt seriously that is where your problem is. I would make certain that you can get flow through the guick couplings on your loader before taking the cover off the hydraulics. Just what I would do. Doesn't mean it is the correct way.
Was the loader working normal when the pump split?
/ HYDRAULIC oil
Hello Winston1
The loader worked perfect,hydraulic gear box ok and 3point ok.
It looks like there is to much pressure going into the system. I am new to computers and do not no how to find your private message will that just come as an separrate e-mail ?
thanking you for your help
G
/ HYDRAULIC oil #7
Hello Winston1
G
Look at the top of this page where it says "ALERTS" and click on that, it will take you to your private messages.
In order to have to much pressure going into the system you have blockage someplace. Pressure will not build unless there is restriction. Did you hear any unusual noise at the time the pump split?
/ HYDRAULIC oil
Hi Winston 1 yes I did here a unusual different noise
/ HYDRAULIC oil
Hi winston1. Have click on alerts private messages inbox and there is only one from muhammad welcoming me to the forums.
/ HYDRAULIC oil #10
Check pm's again, I sent the first one to korky. Any idea just where the unusual different noise was coming from?
24 Gauge R Panels (A65640)
24 Gauge R Panels...
Landhonor 24" Semi-Automatic Tire Changer (A62679)
Landhonor 24"...
2022 EZ-GO ELITE...
New/Unused Wolverine 78in Quick Attach Smooth Bucket (A65583)
New/Unused...
2024 SILVERBACK 53CH3A TRI/A CAR TRAILER (A59914)
2024 SILVERBACK...
60in. Loader Forks and Frame Attachment (A61572)
60in. Loader Forks...
