Hydraulic oil for Farmall Super C
   / Hydraulic oil for Farmall Super C #1
B3B
Rockford, IL
John Deere 314, Farmall A, B, C, M, F-20
I just bought a Super C Farmall. The manual says, "Refill the reservoir with the IH "Touch Control" fluid." Since I don't have an IH dealer close by, is there an equivalent hydraulic fluid that I can use in place of it?
   / Hydraulic oil for Farmall Super C #2
I would say the JD 303 would be good. Were did the work at? I also lived in Rockford and Rockton.
   / Hydraulic oil for Farmall Super C #3
Any ISO 32 hydraulic oil will work just fine.
   / Hydraulic oil for Farmall Super C #4
30 weight non detergent motor oil would be the closest to touch control fluid. You can use anything that s Hy Tran compatible also.
   / Hydraulic oil for Farmall Super C #5
+1 on 303 and wallyworld sells it in the 5 gallon bucket for a song and it's marked 303 as the label.
I worked at Barber-Colman for 40 years, retiring in Feb., 2003
   / Hydraulic oil for Farmall Super C #7
I only lived 3 blocks from the Loves Park plant{Hollis ave.} and I also worked there in the paint booth for a short time, maybe 1 1/2 years and that would of been about the time you started there. I lived on hollis in all of the 70's and early 80's. Small world!!!!!!!!
New Holland C238 Compact Track Loader Skid Steer (A52377)
New Holland C238...
John Deere HPX615E Gator 4x4 Utility Cart (A51691)
John Deere HPX615E...
2011 Crown Victoria Sedan (A51694)
2011 Crown...
LMC G300JD LOT NUMBER 245 (A53084)
LMC G300JD LOT...
JOHN DEERE 5075GN LOT NUMBER 127 (A53084)
JOHN DEERE 5075GN...
2025 New/Unused Wolverine 36in Hydraulic Backhoe Excavator Thumb (A51573)
2025 New/Unused...
