Hydraulic oil for Farmall Super C
   / Hydraulic oil for Farmall Super C #1
B3B
Rockford, IL
John Deere 314, Farmall A, B, C, M, F-20
I just bought a Super C Farmall. The manual says, "Refill the reservoir with the IH "Touch Control" fluid." Since I don't have an IH dealer close by, is there an equivalent hydraulic fluid that I can use in place of it?
   / Hydraulic oil for Farmall Super C #2
I would say the JD 303 would be good. Were did the work at? I also lived in Rockford and Rockton.
   / Hydraulic oil for Farmall Super C #3
Any ISO 32 hydraulic oil will work just fine.
   / Hydraulic oil for Farmall Super C #4
30 weight non detergent motor oil would be the closest to touch control fluid. You can use anything that s Hy Tran compatible also.
   / Hydraulic oil for Farmall Super C #5
+1 on 303 and wallyworld sells it in the 5 gallon bucket for a song and it's marked 303 as the label.
I worked at Barber-Colman for 40 years, retiring in Feb., 2003
   / Hydraulic oil for Farmall Super C #7
I only lived 3 blocks from the Loves Park plant{Hollis ave.} and I also worked there in the paint booth for a short time, maybe 1 1/2 years and that would of been about the time you started there. I lived on hollis in all of the 70's and early 80's. Small world!!!!!!!!
New/Unused Gold Mountain Container Shelter 20ft x 20ft (A51573)
New/Unused Gold...
CONTACT INFO (A53084)
2016 Chrysler 200 Limited Sedan (A51694)
2016 Chrysler 200...
2018 John Deere 1653 (A53472)
2018 John Deere...
2014 International DuraStar 4300 Terex BT3063 30,000LB Crane Truck (A48081)
2014 International...
2003 JOHN DEERE 350D OFF ROAD DUMP (A51246)
2003 JOHN DEERE...
