Hydraulic Multipliers
/ Hydraulic Multipliers #1
audsp98
Birmingham, AL
Mahindra 3550 HST
Does anyone have any experience using a hydraulic multiplier? Summit Hydraulics makes the kit I've been looking at.
I'm looking at using it 2 add a 2nd function to the rear for top and tilt.
/ Hydraulic Multipliers #2
They make several kits, the plug in one to twos are nice looking kits.
They have them in manual and electric select. Manual is quite a bit cheaper if you can conveniently reach to operate it.
/ Hydraulic Multipliers #3
Do a search for the term “Diverter”, hours of reading awaits you :)
One issue I have with the Fasse type Diverter/multiplier is that all the weight of it and the hoses connected to it is hanging on the eccentric couplers and this on the tractor. One could fabricate some sort of support I guess to help with that issue.
/ Hydraulic Multipliers #4
The problem with those multipliers is that then you have a lot of weight just hanging there off of your remote outlets. Second thing is will it actually plug into "YOUR"outlets. I bought a Fasse setup just like the one you are looking at years ago, and even though the connection point had eccentric ports, it just was not enough to get the spacing right. So ultimately it was impossible to be plugged into the factory Mahindra outlets on my 3215 tractor.
But as I mentioned, they are big and heavy enough that I would not of used them even if it had fit. I believe that the guy that I sold them to had the same problem and he then sold them.
If it were me, I would and do have the control switch on the actual rear remote control lever, waaaaay more convenient. :thumbsup:
Good luck with whatever you do. ;)
PJ Trailers 84"x15' Roll Off Dumpster (A60462)
PJ Trailers...
2021 TORO TRAILER (A65643)
2021 TORO TRAILER...
SHORTWOOD 5 BOLTSTER LOG TRAILER (A64276)
SHORTWOOD 5...
FORD 2810 TRACTOR (A64277)
FORD 2810 TRACTOR...
New/Unused CFG Industrial H15R Mini Excavator (A65579)
New/Unused CFG...
2023 JCB S3246E ELECTIC SCISSOR LIFT (A63276)
2023 JCB S3246E...
