Hydraulic motor size
   / Hydraulic motor size #1
Rio_Grande
Platinum Member
Anyone know what size hydraulic motor I need to drive a post hole auger through a gear box? I am wanting to convert a 3 point digger to a hydraulic. Figure if I add a gearbox to it and mount it from a plate it should work. Then I can use it on the front of my skid steer or tractor!
   / Hydraulic motor size #2
I'd be curious to see if there is some sort of formula that can be used to size a hydraulic motor. I've got a snowblower I've thought about converting over to hydraulic drive.
Any reason this wouldnt work JJ?
Surplus Center - 5.4 CU IN BUCHER BHB090A921200B HYD MOTOR
I will be connecting it to a straight shaft so there is not a need for the splined unit. Although that gives me a few ideas.
I intend to mount straight to the gearbox. then the rest of the unit will be mounted to the skid steer mount.
   / Hydraulic motor size #5
Just about any hyd motor in that range should work.
The rpm shown is for the GPM indicated, and if you can't provide the GPMs, it will run slower.
Will this motor be used with your track loader or something else.
I believe your loader puts out about 19.8 GPM at 2760 psi.
Here is a skidsteer adapter to power any of the 3pt implements you might have.
http://www.skidsteersolutions.com/ProductDetails.asp?ProductCode=EZ-3PT-80-S3
http://www.skidsteersolutions.com/Skid_Steer_LF_3_Point_Adaptors_s/53.htm
http://www.berlon.com/3pt.php
Yes it is primarily for the skid steer.
   / Hydraulic motor size #7
Here are some formulas.
Usually have to start by estimating torque or HP required and work back from that point.
  • Fluid_Power_Formulas_(pdf_216_kb).pdf
   / Hydraulic motor size #9
Would love to see some pix of the direct drive set up.
2014 CATERPILLAR 336EL EXCAVATOR (A52705)
2014 CATERPILLAR...
JOHN DEERE CP 770 (A53084)
JOHN DEERE CP 770...
2017 KUBOTA SVL75-2 SKID STEER (A52705)
2017 KUBOTA...
2008 VOLVO EC460CL (A52472)
2008 VOLVO EC460CL...
2006 KOMATSU WA200-5 WHEEL LOADER (A52705)
2006 KOMATSU...
