Hydraulic motor size
   / Hydraulic motor size #1
Rio_Grande
Platinum Member
Anyone know what size hydraulic motor I need to drive a post hole auger through a gear box? I am wanting to convert a 3 point digger to a hydraulic. Figure if I add a gearbox to it and mount it from a plate it should work. Then I can use it on the front of my skid steer or tractor!
   / Hydraulic motor size #2
I'd be curious to see if there is some sort of formula that can be used to size a hydraulic motor. I've got a snowblower I've thought about converting over to hydraulic drive.
Any reason this wouldnt work JJ?
Surplus Center - 5.4 CU IN BUCHER BHB090A921200B HYD MOTOR
I will be connecting it to a straight shaft so there is not a need for the splined unit. Although that gives me a few ideas.
I intend to mount straight to the gearbox. then the rest of the unit will be mounted to the skid steer mount.
   / Hydraulic motor size #5
Just about any hyd motor in that range should work.
The rpm shown is for the GPM indicated, and if you can't provide the GPMs, it will run slower.
Will this motor be used with your track loader or something else.
I believe your loader puts out about 19.8 GPM at 2760 psi.
Here is a skidsteer adapter to power any of the 3pt implements you might have.
http://www.skidsteersolutions.com/ProductDetails.asp?ProductCode=EZ-3PT-80-S3
http://www.skidsteersolutions.com/Skid_Steer_LF_3_Point_Adaptors_s/53.htm
http://www.berlon.com/3pt.php
Yes it is primarily for the skid steer.
   / Hydraulic motor size #7
Here are some formulas.
Usually have to start by estimating torque or HP required and work back from that point.
  • Fluid_Power_Formulas_(pdf_216_kb).pdf
   / Hydraulic motor size #9
Would love to see some pix of the direct drive set up.
2022 MAXXD BD14 Heavy-Duty Dump Trailer with 14K GVWR and Tandem Axles (A55218)
2022 MAXXD BD14...
1984 GROVE CRANE (A54607)
1984 GROVE CRANE...
2009 Hino 268 Progress VTA72 1500 Gallon Vacuum Truck (A51691)
2009 Hino 268...
Toro Workman 175 Sprayer Cart (A50324)
Toro Workman 175...
UNUSED SWICT 84" QUICK ATTACH BUCKET (A54757)
UNUSED SWICT 84"...
GODWIN CD150 DRI PRIME PORTABLE PUMP (A51406)
GODWIN CD150 DRI...
