Hydraulic Motor/Pump Question
/ Hydraulic Motor/Pump Question #1
ebme96
Warrensburg, MO
Grasshopper 618, John Deere 60
I have an old 52" grasshopper mower that the engine is shot, and the hydros are weak. I checked into new hydros and OUCH, $1,500/peice:eek:. So I thought that if I could find a pump and wheel motors I could build my own system. (I have built several go-karts from old mowers so this doesn't seem out of line) I found a pump on surplus center, and some wheel motors (see links below) I am looking to power it with a 24-27 hp engine. By my figures, this should give me a top speed of 13.4 mph. Anyway, to my question. Is there any reason you hydraulic gurus see that this setup wouldn't work? Am I missing anything? (obviously I will have to use many more parts, resevoir and such) Will this pump and wheel motor set-up handle the load I am imposing on it?
So if anyone can help me out I would be glad to hear from you.......
wheel motors (6.1 CU.IN. | Wheel Motors / Wheel Hubs - Quadra Trading Corp)
pump (0.43 cu in HYDROSTATIC KANZAKI DUP-7A TANDEM PUMP)
(Yea, I know I could just buy a new mower, but that doesn't have the cool factor of "I built it myself" and did you check prices recently on a commercial grade mower?:eek:)
/ Hydraulic Motor/Pump Question #2
One pump requires about 6 HP. X2 - 12 HP
Your motors will turn at 227 rpm. torque is 2,9i4 in lbs or 76 ft lbs
Will that 227 rpm give you the speed you want?
You have enough HP for a larger pump.
The motor you selected, will run on 20 GPM.
GRASSHOPPER LAWN MOWER HYDRO PUMPS
If my calculations are right, 225 rpm with a 20" diameter tire should give me 13.4 mph (approx.). And as far as the torque, anybody have any idea if that is enough? I know the engine I was looking at is rated at 35 ft-lbs but obviously that is a much higher rpm. I am totally green on this torque/horsepower/rpm stuff...... (other than my go-kart/garden tractor with a 10hp motor and bigger pulley flat moves:D)
On the capacity for a bigger pump, I am also going to be running a deck (has 52" thinking about a 61" or 72" deck in the future) so I definitely want to keep enough power for that.
Basically being my first project involving hydraulics I want to make sure there are no obvious mistakes in my product choices.
/ Hydraulic Motor/Pump Question #4
Vehicle drive fomulas:
travel speed: MPH = RPM x wheel dia. inches / 336
Axle torque in inch lbs: T = F x r
T = troque inch lbs
F = force or draw bar pull in lbs
r = whee radius in inches
Grade resistance: F = GR x W
GR= grade resistance in percent (20% is written .20)
w = vehicle gross weight
Most lawn mowers use very little power for travel since they are typically rather light and the power is being used for running the mower deck.
/ Hydraulic Motor/Pump Question #5
I have a Woods 5215 (grasshopper 721) diesel. The hydros are getting weak on mine also. New hydros are 2500 each for mine. The motor is dead reliable and I think it can be adapted to new pumps and motors.
I looked at new pump / wheel motor style ztrs. The larger machines use bigger pumps. Most use two pumps. Each turning a wheel motor. I have been looking at Surplus center to try and get a pump/motor combo that will move my machine properly.
From my amateur and quick calculations you will need to run two pumps that are at least 1 cu in ($120 each) And wheel motors that are around 14 cu in. ($180 each). Both are available in the catalog.
Getting the pumps and wheel motors mounted will require additional pulleys and hoses and mounting brackets.
This is a big heavy mower with a 60 or 72 inch deck. I think this combo is more expensive but much more durable.
Of course I could be wrong and your solution might work perfectly. I hope so. It will be much cheaper if I can use your idea. Be sure to post pics. I'm already planning a winter rebuild.
Thanks alot to all who have replied! oldnslo those formulas have been stowed in my "need to remember folder:)."
Cpjlube: after looking and figuring last night, I am leaning heavily to the dual pump set up with 1.1 cu.in. pumps from surplus center, and some larger wheel motors in the 12-14 cu.in. size. That will give alot more torque for a little more money. I have a neighbor that has a full machine and weld shop so the fab work most likely will be done partly by him. I think this setup will allow me to put a snow blade on it (for light use).
Pictures, I def. will try to post pics! I am just tearing down the mower right now, gonna spray a little paint on the frame where it is chipped, and rewire the whole thing. (did I mention my dad is an electrician:D)
And if anyone has any more comments/advice, chime in! I will be glad to hear it even if you tell me I am all wrong:D and my setup is a failure waiting to happen.......
Merle
/ Hydraulic Motor/Pump Question #7
ebme96,
I don't have a clue what your mower weighs in at but figuring 1800 lbs of tractive effort, 20" diameter wheels and 2500 PSI system pressure I came up with requiring 23 cu.in motors and 1.1 cu.in pumps. These motors seem rather large so please double check my numbers. I have made other mistakes today....
/ Hydraulic Motor/Pump Question #8
ebme96, I don't have a clue what your mower weighs in at but figuring 1800 lbs of tractive effort, 20" diameter wheels and 2500 PSI system pressure I came up with requiring 23 cu.in motors and 1.1 cu.in pumps. These motors seem rather large so please double check my numbers. I have made other mistakes today....
The diesels w 60 decks are around 1500. What formulas were you using to derive your numbers? I'm still learning about hydraulic motors. Any insight is appreciated. I was using torque of the current hydros (eaton 771) and trying to match requirements to available motors in the Surplus Center Catalog. I think a 14-15 cu in will work.
I'm just trying to wrap my mind around how to match up pumps and wheel motors and then getting the drive pulleys on the engine and the pumps to match up properly.
/ Hydraulic Motor/Pump Question #9
Cpjlube
I used 1800 lbs x 10 inch wheel radius to arrive at 18,000 in lbs torque required to propel this mower.
divide the 18000 in lbs by 2 to get 9,000 in lbs required per drive wheel.
Hydraulic motor size formula:
Torque in ft lbs = displacement (CIR) x pressure drop across the motor x mechanical & hydraulic efficiency ( I typically use between .8 & .9) divided by 75.4
9,000 in lbs dived by 12 = 750 ft lbs
750 x 75.4 divided by (2500 x .9) = 25.13 CIR (Cubic Inch / Revolution)
still seems like a large motor for that load but these are the formulas that I have used for figuring propulsion systems on equipment
I am going to make a quick guess that the mower with operator will weigh in at approx. 1200 (that is shooting high). Both the pump and the motors say they can handle 3500 psi int. if I do this build I will probably put a pressure gauge in the system just 'cause I wanna know what pressure I am pushing. (drive a turned-up diesel pickup, and love gauges:D)
Another question, if I do this should I be adding any relief valves? (I just now see the pump has this built into it, is this enough?)
Here are the links to the pumps/motors I am considering.
Motors: 12.2 CU.IN. | Wheel Motors / Wheel Hubs - Quadra Trading Corp
Pumps: 1.10 cu in WHITE HYD PISTON PUMP 101018000012
oldnslo, So the force/draw bar pull in your formula is the weight of the machine? It would seem to me that is overkill but......:eek: Because when you move something on wheels you are at an advantage.......(I am green to all of this so.... :ashamed:)
OK so tell me if I am all wrong..... (It has been a long day, and hard)
I was looking online and found the following formula Horsepower=(Torque x RPM)/5252
So 220 ft-lbs (2640 in. lbs. just a guess slightly below the rated numbers)
220x290/5252=12.2 hp take that times 2 for two motors I am showing 24 hp to the ground?
The mower originally had an 18 hp motor on it, that ran a 62" deck as well.......
So is this totally green redneck (me) off his rocker?
I just zapped any remaining brain power I have, so I am headed home for the day...... will check in again tomorrow.
<edit> I know I am throwing questions at you all faster than a...... well I don't know what. So before I go, thanks a million for all the help! I think I am closer than ever to seeing a little light at the end of the tunnel..... lol
/ Hydraulic Motor/Pump Question #12
Cpjlube I used 1800 lbs x 10 inch wheel radius to arrive at 18,000 in lbs torque required to propel this mower. divide the 18000 in lbs by 2 to get 9,000 in lbs required per drive wheel. Hydraulic motor size formula: Torque in ft lbs = displacement (CIR) x pressure drop across the motor x mechanical & hydraulic efficiency ( I typically use between .8 & .9) divided by 75.4 9,000 in lbs dived by 12 = 750 ft lbs 750 x 75.4 divided by (2500 x .9) = 25.13 CIR (Cubic Inch / Revolution) still seems like a large motor for that load but these are the formulas that I have used for figuring propulsion systems on equipment
Now I see......
I wonder what size pumps and motors an Exmark Lazer Z with a 60" deck has? They might have equal weight. I tried to check the specs but can't seem to get the info.
Of course, the tires are larger......
/ Hydraulic Motor/Pump Question #13
One thing I have forgotten to mention in all these posts is that I am figuring a direct wheel drive style motor. I believe most if not all ZTR mowers has some form of chain drive reduction between the motor and the driven wheel. Any gear reduction is going to reduce the hydraulic motor size by the same amount as the reduction. I.e. 4;1 reduction means the motor can be 4 times smaller.
ebme96,
No you are not off your rocker. sizing hydraulic drives is a challenge and requires some knowledge and a little luck to get them close to right. Two 1 cu.in motors at 3600 RPM will produce 15.5 GPM each and will require approx 26 HP each to operate at 2500 PSI @ full flow. That is one of the reasons it is so hard to size HST drives that typically you can easily stall the prime mover.
You need to determine what drive speed you want to mow at and the amount of force / torque required to propel your mower at that speed. Possibly look at Eatons website under small hydrostatic trans-axles. The 771 size shows input power of 5 HP and output torque of 600+ ft lbs. It has 23 : 1 gear reduction built in.
/ Hydraulic Motor/Pump Question #14
One thing I have forgotten to mention in all these posts is that I am figuring a direct wheel drive style motor. I believe most if not all ZTR mowers has some form of chain drive reduction between the motor and the driven wheel. Any gear reduction is going to reduce the hydraulic motor size by the same amount as the reduction. I.e. 4;1 reduction means the motor can be 4 times smaller. ebme96, No you are not off your rocker. sizing hydraulic drives is a challenge and requires some knowledge and a little luck to get them close to right. Two 1 cu.in motors at 3600 RPM will produce 15.5 GPM each and will require approx 26 HP each to operate at 2500 PSI @ full flow. That is one of the reasons it is so hard to size HST drives that typically you can easily stall the prime mover. You need to determine what drive speed you want to mow at and the amount of force / torque required to propel your mower at that speed. Possibly look at Eatons website under small hydrostatic trans-axles. The 771 size shows input power of 5 HP and output torque of 600+ ft lbs. It has 23 : 1 gear reduction built in.
I have seen a lot of the older ZTRs use the chain drive reduction. The really old grasshoppers used the Eaton Model 7 hydros with chain driven sprockets. The Eaton Gemini hydros eliminated the sprockets and chains. The newer grasshoppers are pump and direct drive wheel motors.
It's funny how this thread started two days after I started researching this subject. Learning a lot. Thanks.
OK, I think this time I have made up my mind. I am now looking at a dual 1.1 cu. in. pump set-up with 15.68 cu. in. motors. That would give me:
mowing speed of approx. 13.5 (wouldn't mind being slightly less but that works)
torque (from my calcs, could be wrong) 266 ft. lbs. @ 1425psi; 516 ft. lbs. @ 2970 psi; 582 ft.lbs. @ 3480 psi
Tractive Force of: cont. 640 lbs.; peak 1400 lbs.
If speed are too high I can always install bigger pulleys on the pumps and slow them down slowing down speeds or block the handles and cut speeds that way...... I am planning on installing a pressure gauge on at least one of the sides, to see what pressure I am pushing.... (aka BOOST:D)
I think I can have the motors and pumps for about a quarter of two new hydros for the mower.
For perspective Dixie Chopper (the only mower that lists cu. in . of wheel motors on website) shows that they run 24 cu. in wheel motors on machines up to 54 hp, 74" cut.
and thanks oldnslo for confirming my sanity:laughing:
/ Hydraulic Motor/Pump Question #16
ebme96,
Good luck on the rebuild and as you know, pictures are always required..
Interesting that Dixie Chopper kind of matched my guess on motor size required.
/ Hydraulic Motor/Pump Question #18
A 1.1 cu in pump turning at 3600 rpm will pump 17 GPM. If relief set to 1425 psi = 17 HP , and then you have two of the pumps.and will require about 34 HP.
Even if the pumps only pump 15 GPM, that is still 30 HP for both pumps.
The 1425 psi for continuous operation, but will go to 3500 peak. It will stall at this pressure.
NEW HOLLAND B95B BACKHOE (A62129)
NEW HOLLAND B95B...
GENIE GS-1930 ELECTRIC SCISSOR LIFT (A62129)
GENIE GS-1930...
New/Unused Landhonor 6ft x 8ft Galvanized Apex Roof Metal Shed (A61166)
New/Unused...
TSURUM HSZ3-755 PUMP-1 PHASE INDUCTION PUMP (A62131)
TSURUM HSZ3-755...
2016 Ford Explorer AWD SUV (A61569)
2016 Ford Explorer...
(2) UNUSED 23X8.50-14 TIRES W/6 LUG RIMS (A62130)
(2) UNUSED...
