hydraulic logging winch
/ hydraulic logging winch
</font><font color="blue" class="small">( .
I didn't read about your winch test. Were you able to load the winch and work it to see what happened? )</font>
i loaded it and ran it for five minutes or so.
i'll more than likely only be winching for less then five minutes at a time.
then i'll be transporting it to a bucking area, bucking it and going back for another.
thanks for the input, i'll be keeping a close eye on the temp.
/ hydraulic logging winch #22
The logging winch load isn't continuous. It would not be a problem. The fluid capacity is pretty large. If you plumbed up something with an orifice in it and ran it continuous it would heat you out in a hurry.
/ hydraulic logging winch #23
I have an 8000lb hyd winch that I use in my loader. I have never had a heating problem with the hydraulics. Even on full pulls of the line, 75ft, I don't notice any heat. The winch it'self will warm up some, but not the hyd oil. One thing I have to ask. Do you have a way to freespool the winch or do you have to play out the line with the hyd motor, and is the load held by the motor, or do you have a locking lug to hold the load?
</font><font color="blue" class="small">( I have an 8000lb hyd winch that I use in my loader. I have never had a heating problem with the hydraulics. Even on full pulls of the line, 75ft, I don't notice any heat. The winch it'self will warm up some, but not the hyd oil. One thing I have to ask. Do you have a way to freespool the winch or do you have to play out the line with the hyd motor, and is the load held by the motor, or do you have a locking lug to hold the load? )</font>
yes it has a free spool and the load is held in place by the motor.
additionally i have an electric winch receiver mounted on the front of the tractor.
/ hydraulic logging winch #25
Unless you were running the winch all day. I doubt you would have any problems. Most of the pto logging winches come standard with at least 150' of cable and depending on cable size can accommodate 400'. For a pull that long, I'd be concerned about heat build up with a hydraulic setup. I'm not sure how you'd know when the tractor transmission was getting cooked since a tractor, especially on a hot day, puts out quite a bit of heat anyway.
I was considering running an auger with an hydraulic motor of about 1/3 hp to load lime when I was warned. One of my future projects is to add a transmission temp gauge to a Kubota hydrostatic just to check baseline temps.
/ hydraulic logging winch #26
What about using a cooler/radiator on the return line? They have small fans that you could adpat from a car and have the cooler situated with your attachment so it would only be in use with that item. Easier to do with a logging winch than a PHD though /forums/images/graemlins/tongue.gif. Just thinking aloud /forums/images/graemlins/frown.gif
</font><font color="blue" class="small">( Unless you were running the winch all day. I doubt you would have any problems. Most of the pto logging winches come standard with at least 150' of cable and depending on cable size can accommodate 400'. For a pull that long, I'd be concerned about heat build up with a hydraulic setup. I'm not sure how you'd know when the tractor transmission was getting cooked since a tractor, especially on a hot day, puts out quite a bit of heat anyway.
I was considering running an auger with an hydraulic motor of about 1/3 hp to load lime when I was warned. One of my future projects is to add a transmission temp gauge to a Kubota hydrostatic just to check baseline temps. )</font>
it would be easy to add a gauge in line on one of the winch motor lines.
i might even all ready have a gauge to rig up.
on another note i don't have a hydrostatic transmission.
</font><font color="blue" class="small">( What about using a cooler/radiator on the return line? They have small fans that you could adpat from a car and have the cooler situated with your attachment so it would only be in use with that item. Easier to do with a logging winch than a PHD though /forums/images/graemlins/tongue.gif. Just thinking aloud /forums/images/graemlins/frown.gif )</font>
while the motor does have a free spool mode it can also be run in both directions, so a special high pressure cooler would be needed.
/ hydraulic logging winch #29
Sorry, he doesn't need a cooler, there are many commercial hydraulic logging winches around, none with a cooler.
Even the little milemarker winches on pickups with 1/2 quart reservoir get by although many add coolers to those.
The tractor holds what 10 gallons of hydraulic fluid? Some already have a cooler too.
/ hydraulic logging winch #30
Ten gallons of hydraulic fluid may be enough. The hydraulics on commercial machines are designed with the potential heat load in mind. I've also got a Unimog which has a hydraulic system with a five gal. capacity. I was also warned about overheating the hydraulic system on that tractor after I called a Unimg specialist on an unrelated matter and mentioned the 20T winch mounted on the back deck above the 3 pt hitch.
If you have a commercial machine or one with lots of hydraulic fluid in the system you might be safe. A $20 gauge to monitor trans temp is still cheaper than an overhaul to repair cooked seals. The other point is if someone does cook the seals on a tractor under warranty while using a non-approved device, do you think the manufacturer will honor the warranty?
I once ran a 76 B300 Dodge van down the road with a triaxle trailer loaded with a camping trailer filled with furniture not to mention the load in the truck. I was hauling 16,000+ lbs. I had a trans cooler with temp gauges monitoring the temps in and out on the cooler. That saved my bacon on the Pennsylvania hills. I could see the input temp into the cooler climbing. Even with a cooler, it won't do you any good when the temp in the tranny starts to reach the brakedown point of the fluid. I kept pulling over and letting everything cool down. I made it to the end of my trip of 1,200 miles without blowing the tranny. In fact when the truck died in a head-on with 140K, the tranny had never been touched other than fluid and filter changes.
I'm a firm believer in gauges.
2023 Takeuchi TL6R Compact Track Loader Skid Steer w Low Hours (A61307)
2023 Takeuchi TL6R...
2016 GMC Seirra Denali 1500 4x4 Crew Cab Pickup Truck (A60352)
2016 GMC Seirra...
GROVE RT 63S HEAVY DUTY HYDRAULIC CRANE (A60736)
GROVE RT 63S HEAVY...
UNKNOWN  20 FLATBED GOOSENECK (A58216)
UNKNOWN 20...
2013 JLG 8K TELEHANDLER (A58214)
2013 JLG 8K...
JEEP FOR DOUBLE TRAILER (A58214)
JEEP FOR DOUBLE...
