Hydraulic level plug replacement
/ Hydraulic level plug replacement #1
Tullfish
Ford 4600
Hi,
I had a hard time removing a worn down level plug, and probably affected the female threads on the tractor case doing so. It seem to be a 1/2 inch tapered plug. If I find a replacement plug, could it kind of "re-thread" the female treads? Or should I re-thread the whole thing a size higher?
Sylvain
/ Hydraulic level plug replacement #2
There is a danger of getting metal filings in the hydraulic oil by re-threading. If you can find a replacement plug you should probably use some Teflon thread seal tape on it to get a good seal.
2019 Krause 8005-30 Excelerator - High Speed Vertical Tillage - 30 FT Working Width (A63688)
2019 Krause...
2015 Deere 210G (A64126)
2015 Deere 210G...
1993 Transcraft 38Ft Step Deck trailer (A64194)
1993 Transcraft...
Landhonor 3Pt Potato Harvester (A66285)
Landhonor 3Pt...
2016 JCB 507-42 (A64126)
2016 JCB 507-42...
New/Unused Wolverine Mini Combination Bucket (A65583)
New/Unused...
