Hydraulic level plug replacement
/ Hydraulic level plug replacement #1
Tullfish
Ford 4600
Hi,
I had a hard time removing a worn down level plug, and probably affected the female threads on the tractor case doing so. It seem to be a 1/2 inch tapered plug. If I find a replacement plug, could it kind of "re-thread" the female treads? Or should I re-thread the whole thing a size higher?
Sylvain
/ Hydraulic level plug replacement #2
There is a danger of getting metal filings in the hydraulic oil by re-threading. If you can find a replacement plug you should probably use some Teflon thread seal tape on it to get a good seal.
New/Unused Landhonor 26ft x 13ft Metal Carport (A65583)
New/Unused...
2020 Peterbilt 567 Quint Dump (A62613)
2020 Peterbilt 567...
New/Unused ATS Welding Machine (A65583)
New/Unused ATS...
213141 (A64276)
213141 (A64276)
2022 EZ-GO ELITE...
20' Reids Trailer (A62613)
20' Reids Trailer...
