• Thank you for participating in the Summit Tractors Community. Per special arrangement with the TBN team, Summit Tractors will regularly monitor and contribute to this forum to help ensure that the community has direct access to Summit. You can ask and find answers to a range of topics directly from Summit and from other TBN users. The Summit Tractors brand is here to stay with the recent acquisition of the Summit Tractors brand by ITL, the 5th largest tractor manufacturer in the world. Yes, we make our own tractors, something very important for our owners and prospective owner to know. Summit’s founder continues to lead operations and the U.S. team that supports our retailers, tractor owners and TBN users.
Ad top of page
Hydraulic leaks
/ Hydraulic leaks #21
Do you put them on the op and bottom of the fitting?
/ Hydraulic leaks #23
thx, just got my hose yesterday, a take off as well...
/ Hydraulic leaks #24
White4768, I am curious about your routing solution to prevent this from happening again
/ Hydraulic leaks
I sent it under the right side frame rail and turned the other hose to match it. Worked out good
/ Hydraulic leaks #26
Any one else have a hydraulic line burst right under the floor mat? It was pinched between the floor board and the frame and the forward pedal pedal pivot was was rolling right under it you can see it in pic 2. It all most cut the hose in half.
I've had my TX25 for about 10 months now. I have had numerous leaks. Every connection on the grapple was only hand tight. I had a leak on the loader return line that leaked from the factory crimp. I had a leak on the backhoe supply line that leaked 3 gallons before I got off and saw the huge puddle under the tractor; this line was also only hand tight. I would recommend checking every connection for tightness when you first get your machine because obviously there is no QC check on the hydraulic fittings before they leave the factory.
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Location Info Please
2017 New Holland T4.110 Cab 4WD w/ 655TL Loader – 1,619 hrs – Excellent Condition
2017 New Holland...
2019 BOBCAT SKIDSTEER T740 (A60736)
2019 BOBCAT...
2019 FORD F-150 XL SINGLE CAB TRUCK (A59823)
2019 FORD F-150 XL...
Ad bottom of page
