Hydraulic Hose
/ Hydraulic Hose #1
daBear
Brandon, MS
Kubota L2800
In a thread I started about this time last year I asked several TNT questions about my Kubota L2800 which puts out 2400 psi. pressure and has 7.0 gal per min flow rate. Finally, I am ready to get the cylinders and joystick parts from Carter & Carter and have questions about the hose. What size ID hose is typically used on compact tractors with TNT? How many wire layers in the hose? I see everything from one layer to six?
I will probably have a local hydraulic shop do the hoses for me and I wanted to at least know a little about what I was doing before I went. Thanks.
/ Hydraulic Hose #2
For a TnT setup you want 1/4", 2-wire, 3000min PSI rated hose.
/ Hydraulic Hose
Wow, that was quick, tanks kennyd. A question I am going to ask C&C when I call them is about quick disconnects put in the system after the 2 spool joystick control. I do not want to plumb the cylinders directly into the control but rather use quick disconnects in case I need power to something else. I could put another joystick in for power beyond but that would be expensive. If I just had to I could put the OEM top link or side link back in for a while and use the existing quick couplers as rear remotes, couldn't I?
/ Hydraulic Hose #4
Putting QD's on your TnT cylinder is pretty commonplace, a lot of guy's take the cylinders off especially when they have backhoes.
/ Hydraulic Hose #5
CCM added QD's and hoses to my TL before they sent it out. Just checked their site, it adds 45$ to the price. DO IT!!! It was roughly 8 minutes from the time I opened the box 'til I was topping away with glee!!!
-Jer.
