Hydraulic Hose Size
   / Hydraulic Hose Size #1
jgbanshee
PA
JD 310SE, 4300, 5300, 5210, 450 Crawler, CAT D3B, Ford 2N, 5000, 4000su, 3610, 345C, 340B, 1100
I plan on routing two hydraulic hoses from my rear remotes up to the cross-member between the FEL arms for a grapple and power angle snow plow. My tractor specs the max flow for the rear remotes is 8 GPM. Should I use 3/8" hose with 1/2" QC's or 1/2" hose with 1/2" QC's. Either way the hose length will be 16' long. I dont think that heat is a problem because they are only used for a grapple and snow plow.
   / Hydraulic Hose Size #2
I used 3/8 for both uses with no problem. Some guys suggest 1/4 for grapple to slow them down.
   / Hydraulic Hose Size #3
That's what I'd do.. 1/4 hoses.. cheaper too.
soundguy
   / Hydraulic Hose Size #4
soundguy
I agree, 1/4" hoses. The 8 GPM figure is irrelevant because its not the cylinders for the plow or grapple do not require constant flow.
So, the majority agrees that I should use 1/4" hose. Does the 8 GPM rating matter for any implement? What size QC's should I use?
   / Hydraulic Hose Size #7
yeah.. hyd motors.. that's where high sustained flow is needed.
soundguy
   / Hydraulic Hose Size #8
It is recommended to use one size larger QC for full flow.
   / Hydraulic Hose Size #9
I think he's actually looking 'for' restriction.. if he wanted full flow.. we'd be telling him 3/8 hose at least.
soundguy
   / Hydraulic Hose Size #10
If you think you might ever use a hyd motorized attachment on the front, I would go with 3/8 in hose, and 1/2 QC's. You could still add a restrictor in the line, or a needle valve.
2008 VOLVO VHD64B CRANE TRUCK (A52141)
2008 VOLVO VHD64B...
2019 KENWORTH T680 SLEEPER (A52577)
2019 KENWORTH T680...
King Kutter 6' 3 pt Mower (A50515)
King Kutter 6' 3...
UNUSED FUTURE 5T HYD THUMB CLAMP (A51244)
UNUSED FUTURE 5T...
2018 JLG 3246ES 32FT. Electric Scissor Lift (A51691)
2018 JLG 3246ES...
2015 MACK ELITE LEU633 GARBAGE TRUCK (A51243)
2015 MACK ELITE...
