Hydraulic Hose Size
/ Hydraulic Hose Size #1
jgbanshee
Gold Member
PA
JD 310SE, 325G, 35G, 4300, 5300, 5210, 445, 450 Crawler, CAT D3B, Ford 2N, 7000, 5000, 4000su, 3610, 445D, 345C, 340B, 1100
I plan on routing two hydraulic hoses from my rear remotes up to the cross-member between the FEL arms for a grapple and power angle snow plow. My tractor specs the max flow for the rear remotes is 8 GPM. Should I use 3/8" hose with 1/2" QC's or 1/2" hose with 1/2" QC's. Either way the hose length will be 16' long. I dont think that heat is a problem because they are only used for a grapple and snow plow.
/ Hydraulic Hose Size #2
I used 3/8 for both uses with no problem. Some guys suggest 1/4 for grapple to slow them down.
/ Hydraulic Hose Size #3
That's what I'd do.. 1/4 hoses.. cheaper too.
soundguy
So, the majority agrees that I should use 1/4" hose. Does the 8 GPM rating matter for any implement? What size QC's should I use?
/ Hydraulic Hose Size #7
yeah.. hyd motors.. that's where high sustained flow is needed.
soundguy
/ Hydraulic Hose Size #8
It is recommended to use one size larger QC for full flow.
/ Hydraulic Hose Size #9
I think he's actually looking 'for' restriction.. if he wanted full flow.. we'd be telling him 3/8 hose at least.
soundguy
/ Hydraulic Hose Size #10
If you think you might ever use a hyd motorized attachment on the front, I would go with 3/8 in hose, and 1/2 QC's. You could still add a restrictor in the line, or a needle valve.
/ Hydraulic Hose Size #11
He could also just save the money, do the 1/4 now, and if he ever goes to a motor.. get brand new hoses when he gets the motor. If he waits 4-5-6 ys for the motor.. no reason to have old hoses on it, vs new ones.
I know bigger is better in general.. but we don't need to overthink the original posters state issue he is trying to solve... IMHO.
soundguy
/ Hydraulic Hose Size #13
I used 1/4" hose 17' long to run the power angle on my plow. My system is 6 gpm I believe and it works great. I had 1/2"QC at the rear but not issues. My setup is just temporary when the plow is on.
Chris
/ Hydraulic Hose Size #14
I would suggest this rather than smaller hoses. Variable control, set it and forget it, until you need full flow.
https://www.surpluscenter.com/item.asp?UID=2009102213494517&item=9-5300-38&catname=hydraulic
Nice valve.. again though.. it adds another what? 40$ by the time it's shipped.. to the price of his setup.
1/4 lines with 1/4 connectrs are gonna do exactly what this guy needs.. vs the expense of large lines.. large connectors, and flow control valves.
this issue is getting way overworked... it's a penny problem with nickle, dime and quarter answers.
soundguy
/ Hydraulic Hose Size #15
Used 1/4 hoses for my snow plow from the rear. its slower to angle but not worth the price difference. surplus center was the cheapest even shipped. beat all of our tractor places and our auto part stores. same identicle hose as i could get here but half the price.. and besides doe you want to ty up that heavy half inch hose 1/4 is easy to work with
/ Hydraulic Hose Size #16
soundguy
Thank-you Soundguy, thank-you from the bottom of my heart!
/ Hydraulic Hose Size #17
jgbanshee ,
It's your tractor, just do what you want.
Thanks everyone for your thoughts. I decided to go with the 3/8" hose with 3/8" QC. For the snow plow end i am going to use 1/4" hose.
