Hydraulic Hose Size
   / Hydraulic Hose Size #1
jgbanshee
PA
JD 310SE, 4300, 5300, 5210, 450 Crawler, CAT D3B, Ford 2N, 5000, 4000su, 3610, 345C, 340B, 1100
I plan on routing two hydraulic hoses from my rear remotes up to the cross-member between the FEL arms for a grapple and power angle snow plow. My tractor specs the max flow for the rear remotes is 8 GPM. Should I use 3/8" hose with 1/2" QC's or 1/2" hose with 1/2" QC's. Either way the hose length will be 16' long. I dont think that heat is a problem because they are only used for a grapple and snow plow.
   / Hydraulic Hose Size #2
I used 3/8 for both uses with no problem. Some guys suggest 1/4 for grapple to slow them down.
   / Hydraulic Hose Size #3
That's what I'd do.. 1/4 hoses.. cheaper too.
soundguy
   / Hydraulic Hose Size #4
soundguy
I agree, 1/4" hoses. The 8 GPM figure is irrelevant because its not the cylinders for the plow or grapple do not require constant flow.
So, the majority agrees that I should use 1/4" hose. Does the 8 GPM rating matter for any implement? What size QC's should I use?
   / Hydraulic Hose Size #7
yeah.. hyd motors.. that's where high sustained flow is needed.
soundguy
   / Hydraulic Hose Size #8
It is recommended to use one size larger QC for full flow.
   / Hydraulic Hose Size #9
I think he's actually looking 'for' restriction.. if he wanted full flow.. we'd be telling him 3/8 hose at least.
soundguy
   / Hydraulic Hose Size #10
If you think you might ever use a hyd motorized attachment on the front, I would go with 3/8 in hose, and 1/2 QC's. You could still add a restrictor in the line, or a needle valve.
Caterpillar Loader Quick Coupler (A52128)
Caterpillar Loader...
UNUSED FUTURE EQUIPMENT SEAT (A51244)
UNUSED FUTURE...
Heritage / Woods RD 72 3 pt Finish Mower (A50515)
Heritage / Woods...
2008 SATURN VUE (A50324)
2008 SATURN VUE...
2013 VOLVO VNM TANDEM AXLE DAY CAB (A52141)
2013 VOLVO VNM...
Skid Steer Plate Attachment (A50322)
Skid Steer Plate...
