Oil & Fuel Hydraulic foam on bx25d
/ Hydraulic foam on bx25d #1
pabx25d
Pittsburgh, PA
Kubota BX25D
Hello all,
I have a new bx25d with < 10 hrs. Yesterday, I ran it around the yard for about 20 minutes to check the adjustment of the mmm prior to the first mow of the year.
After finishing, I pulled the transmission dipstick and noticed air bubbles in the hydraulic fluid. These bubbles were small enough that the fluid appeared cloudy at first glance. I restarted the tractor, and found light foaming while running. After shutting the tractor off, the fluid eventually clarified as the bubbles worked their way out.
Have any other BX owners checked the hydraulic fluid while running? Is some air common in these systems? Tractor runs fine with no apparent loss of power or outstanding pump noise. It also lives in the garage, so I don't suspect water intrusion.
/ Hydraulic foam on bx25d #2
Some aeration is normal. But check that the oil is not overfilled; if it is too high, it can get churned by the gearset above the reservoir.
wrooster
/ Hydraulic foam on bx25d #3
wrooster
Does this mean any bit overy max level line should be drained?
2012 Dodge Ram 1500 4wd (A62679)
2012 Dodge Ram...
2022 John Deere Z930M (A57148)
2022 John Deere...
(2) 380/85R30 TIRES W/ 8 LUG RIMS (A64280)
(2) 380/85R30...
7' ROTARY MOWER (A63291)
7' ROTARY MOWER...
WoodMaxx MX 9900 with almost no use
WoodMaxx MX 9900...
Black Jet Dock Drive-On (A59228)
Black Jet Dock...
