hydraulic fluid
/ hydraulic fluid #1
ihuntbear
new brunswick, canada
2015 tym T554 and 1999 Kobota m4700
I noticed that my hydraulic oil is clear on the dipstick.Back in the day we used to add a little red trans fluid to the hyd fluid to give it color for easy checking.Does anybody know if i can still do this ? I called the dealer today,he said he didn't know,it might void the warrenty.Is there anytrhing in the trans fluid that could eat the lining of the hoses or orings
/ hydraulic fluid #2
ATF is used in a good many hyd systems. I doubt it will hurt anything. Watch out for the warranty catch 22.
/ hydraulic fluid #4
ATF is a little more than just red dye in hydraulic fluid, but there is nothing in ATF that would harm a hydraulic system.
We tend not to use ATF because it is more hydrophilic than straight hydraulic fluid and that can be a major issue in our industry.
/ hydraulic fluid #5
John Deere sells red dye for a decent price:
Part Details
Part Number:
MT3668 Part Price: 3.91 USD On Hand:
0 Check Other Stores Description: FLUID, HYDRAULIC OIL DYE
/ hydraulic fluid #6
I just used this dye to tint up so low viscosity HyGuard for my 318. It took about 3 drops to tint up 1.75 gallons, two probably would have worked just fine. There's not much in the jar, but you don't need much. Use a small eye dropper to control how much you add. Start small.
Got the part number from kennyd, had my JD dealer order it.
Pete
1994 Ford F700 Fuel Tanker Truck (A64556)
1994 Ford F700...
Pallet of Miscellaneous Duplex Polyester Webbing Slings (A64553)
Pallet of...
2019 Peterbilt 579 T/A Sleeper Cab Truck Tractor (A64556)
2019 Peterbilt 579...
2021 Mac Trailers T/A Walking Floor Trailer (A64556)
2021 Mac Trailers...
2009 Ford F-150 Pickup Truck (A64194)
2009 Ford F-150...
2016 Isuzu NRR Elgin Broom Badger Sweeper Truck (A64556)
2016 Isuzu NRR...
