Hydraulic Fluid Replacement
/ Hydraulic Fluid Replacement #1
rocknrod
Hico, TX
LS Tractor, Model R4010
So what is consensus on the brand and type of hydraulic fluid to use when replacing it?
/ Hydraulic Fluid Replacement #2
My choice was SUDT. It flows better in cold weather.
/ Hydraulic Fluid Replacement #5
I'm using Kubota UDT ------------ I don't have to worry about too much cold weather.
/ Hydraulic Fluid Replacement #6
I use straight old Kubota UDT. Have been told many times by seperate dealers that the SUDT & SUDT2 are best for units with hydraulic motors - i.e.- tracked back hoes, skid steers etc. The synthetic & synthetic 2 will not harm a standard tractor but are a unnecessary waste of $$$$.
/ Hydraulic Fluid Replacement #7
This what my dealer gave me for my gear drive.
/ Hydraulic Fluid Replacement #8
/ Hydraulic Fluid Replacement #9
I use the Traveler Premium in my Hydro. From what I read here on TBN, it is up to most Mfg's specs, and it is good for cold climates.
/ Hydraulic Fluid Replacement #10
I haven't completely changed the Hyd. fluid but this is what I used to top off after the 50 hr. filter change.
I bought this at Advance Auto Parts.
I have also used the Travelers brand at TSC in other HST tractors.
/ Hydraulic Fluid Replacement #11
I was pretty stressed out about it ... I expected my dealer to have the right stuff and they were like ... uh, use hydraulic fluid. And that was the attitude of other dealers around here so then I did my own research and settled on the Premium Travelers. One of my co-workers who's family always had tractors laughed at me when I asked his opinion too and was like ... uh, hydraulic fluid. :confused2:
I guess I have a touch of OCD, I mean I do used oil analysis on my TDI's engine oil.
/ Hydraulic Fluid Replacement #12
Ya, as long as u use the premium stuff your good. The regular stuff isn't for Hydro's and Wet brakes.
/ Hydraulic Fluid Replacement #13
I posted the pic of my fluid so you could see the spec's as long it good for wet brakes you are good.
/ Hydraulic Fluid Replacement #14
I use Chevron Synthetic All-Weather THF in my G3033H mainly because its so cold here in the winter but it works great all year round. I used it in my kubota BX25 year round with excellent results. So for extreme cold weather, Chevron Synthetic All-Weather THF would be a go to for HSD tractors.
(5) Round Grass Hay Bales (A66408)
(5) Round Grass...
2019 GMC SIERRA HD 3500 (A63569)
2019 GMC SIERRA HD...
MAC Hi Power Towable Generator (A65579)
MAC Hi Power...
3-Pt Disk (A66285)
3-Pt Disk (A66285)
2018 KENWORTH T680 6X4 T/A SLEEPER TRUCK TRACTOR (A67147)
2018 KENWORTH T680...
Peruzzo Canguro 1600 Collection Flail Mower
Peruzzo Canguro...
