Hydraulic Fluid Replacement
/ Hydraulic Fluid Replacement #1
rocknrod
Hico, TX
LS Tractor, Model R4010
So what is consensus on the brand and type of hydraulic fluid to use when replacing it?
/ Hydraulic Fluid Replacement #2
My choice was SUDT. It flows better in cold weather.
/ Hydraulic Fluid Replacement #5
I'm using Kubota UDT ------------ I don't have to worry about too much cold weather.
/ Hydraulic Fluid Replacement #6
I use straight old Kubota UDT. Have been told many times by seperate dealers that the SUDT & SUDT2 are best for units with hydraulic motors - i.e.- tracked back hoes, skid steers etc. The synthetic & synthetic 2 will not harm a standard tractor but are a unnecessary waste of $$$$.
/ Hydraulic Fluid Replacement #7
This what my dealer gave me for my gear drive.
/ Hydraulic Fluid Replacement #8
/ Hydraulic Fluid Replacement #9
I use the Traveler Premium in my Hydro. From what I read here on TBN, it is up to most Mfg's specs, and it is good for cold climates.
/ Hydraulic Fluid Replacement #10
I haven't completely changed the Hyd. fluid but this is what I used to top off after the 50 hr. filter change.
I bought this at Advance Auto Parts.
I have also used the Travelers brand at TSC in other HST tractors.
/ Hydraulic Fluid Replacement #11
I was pretty stressed out about it ... I expected my dealer to have the right stuff and they were like ... uh, use hydraulic fluid. And that was the attitude of other dealers around here so then I did my own research and settled on the Premium Travelers. One of my co-workers who's family always had tractors laughed at me when I asked his opinion too and was like ... uh, hydraulic fluid. :confused2:
I guess I have a touch of OCD, I mean I do used oil analysis on my TDI's engine oil.
/ Hydraulic Fluid Replacement #12
Ya, as long as u use the premium stuff your good. The regular stuff isn't for Hydro's and Wet brakes.
/ Hydraulic Fluid Replacement #13
I posted the pic of my fluid so you could see the spec's as long it good for wet brakes you are good.
/ Hydraulic Fluid Replacement #14
I use Chevron Synthetic All-Weather THF in my G3033H mainly because its so cold here in the winter but it works great all year round. I used it in my kubota BX25 year round with excellent results. So for extreme cold weather, Chevron Synthetic All-Weather THF would be a go to for HSD tractors.
S/A Towable Solar Speed Radar Trailer (A64194)
S/A Towable Solar...
34in. Bucket with Teeth Excavator Attachment (A64194)
34in. Bucket with...
Barrel (A64557)
Barrel (A64557)
2021 Ford F-150 4x4 Crew Cab Pickup Truck (A64556)
2021 Ford F-150...
2026 Electric Tricycle (A64194)
2026 Electric...
New/Unused Mini Quick Attach Auger with Bit (A65583)
New/Unused Mini...
