Hydraulic Flow Meter
/ Hydraulic Flow Meter #11
Mark,
Put a pressure guage on it first before you pull the valve. That may save you some unnecessary work.
ron
Eureka!
I have narrowed down the source of the problem significantly.
I have my gauge, hose, and fittings now so I checked the pressure at the plug near the control valve. I got no response on the gauge. I started wondering if there was any flow at all or if I had a defective gauge. I removed the fill cap, removed the gauge from the hose, and put the hose down into the fill hole so that I could see for sure that at least there was some flow. As I pushed the position control lever, I noticed that there was some splashing that seemed to be unrelated to the flow from the hose. I removed the hose and put the plug back into the port. I pushed the position control lever again and there was that splashing again. What that means to me is that the fluid is bypassing the cylinder hence no pressure! I have already made adjustments to the relief valve so I think it might be something else.
The WSM has a trouble shooting section so I am just going to have to go through all of the items that relate to fluid bypassing the cylinder.
Getting closer
Mark
Finally, It works!
For the most part, I have just been using the tractor to drag the mowing deck around the yard so it wasn't critical that the 3ph worked, but it was bugging me so I finally decided to pull the hydraulic block off the top of the tractor. Everything inside looked absolutely pristine. The only thing that I did was to replace the O-rings on every component inside. There were 7 O-rings in total including one for the master cylinder. The total expense for the O-rings was $5.19 from the place that quoted me $1100.00 to do the same job that I did. The O-rings I pulled out looked perfectly good. I put the calipers on one of the old O-rings and compared that to the new O-ring and the new one was about .004" (four thousandths of an inch) bigger than the old one. I didn't check the rest of them but apparently that did the job because when I put everything back together, the mower deck raised right off the ground when I pulled back on the lever.
I think I'll grade the driveway this weekend.
/ Hydraulic Flow Meter #14
Don't forget to tell the wife you saved $1094.81! (don't expect a pat on the back from her....) Still, good job finding a strange problem.
jb
ENCLOSED DRIVING SIMULATOR TRAILER (A58214)
ENCLOSED DRIVING...
2019 CHEVROLET SILVERADO CREW CAB TRUCK (A59823)
2019 CHEVROLET...
2021 CATERPILLAR 302.7DCR EXCAVATOR (A62129)
2021 CATERPILLAR...
Harlo HP6500 (A60462)
BUYERS PREMIUM & PAYMENT TERMS (A59906)
BUYERS PREMIUM &...
2020 DRAGON ESP...
