Hydraulic fitting leak
/ Hydraulic fitting leak #1
wendlingknives
East TX
TYM 574HC
One of the fittings for my front remote (for grapple) is leaking pretty decent. Checked and its screwed on tight. Only leaks when the hose for grapple is connected, so I should take that to mean theres something wrong with the fitting? Ive also seen that there are 2 types of fittings, one has a ball, one has more of a cone shape detent. Is one preferred to the other?
/ Hydraulic fitting leak #2
Could be dirt in the fitting. Brake clean and compressed air clean them out good.
/ Hydraulic fitting leak #3
Is it leaking from the threads? OR is it leaking from the connection of the two couplers?
Is it just a drip or two....or is it a high pressure spray of fluid?
Leaking from inside the connection. Its a pretty steady drip
/ Hydraulic fitting leak #5
O ring pinched or ripped? You can replace them but it can be fiddly. You do have to know what type and size coupling you have. Seems like there are way to many types/sizes in use these days.
NEW ATA-EPC40 Plasma Cutter (A62679)
NEW ATA-EPC40...
John Deere 6110M (A64126)
John Deere 6110M...
2022 CATERPILLAR 299D3 SKID STEER (A62129)
2022 CATERPILLAR...
2009 Infiniti G37 Coupe (A64557)
2009 Infiniti G37...
New/Unused 2 Post Car Lift (A65583)
New/Unused 2 Post...
2005 Amadas 2100 (A64126)
2005 Amadas 2100...
