Hydraulic filter damaged
/ Hydraulic filter damaged #21
_RaT_ said:
I don't know but it is available as Brand GM, or rebadged GM from your local GM/Chevy dealer
At 8-9 bucks a can, there's got to be a way to cut out the middleman. AeroKroil is $6.75/can if you buy a case.
The metal filter strap has a rubber liner on the inside. Tried it and it totally crushed the filter. I can't even get a bite with it now. FANTASTIC! Something that should take a few minutes it resulting in several hours. This makes me so happy to spend more time around the Bota than on it :mad:
Next will be the screw driver trick and if that doesnt work the sledge hammer trick. I will let you know what happens:cool:
/ Hydraulic filter damaged #23
But how is GM going to cover the retirement, medical, etc for each employee for their lifetime? :eek:
/ Hydraulic filter damaged #24
does not cost me a dime :D
duno who makes it there is no company name on the entire can but gm
GOT IT! :D Apparently the rubber gasket expands and contracts and if over tightening occurred it binds. That along with the dirt and rust made it quite difficult. I sanded some of the paint off the filter for a better grip and then I was able to use the strap wrench at the top of the filter.
Thanks for your help.
265/75R16 New Tire (A62613)
265/75R16 New Tire...
IRanch High-End Tricycle (A64119)
IRanch High-End...
1986 Trailmobile F71T-6UJA 40ft. 32 Ton T/A Flatbed Trailer (A64194)
1986 Trailmobile...
Dickson Ind. 4080 SX Turbo Blast Asphalt Surface Prep Machine (A64194)
Dickson Ind. 4080...
12 in. WRXLS Excavator Bucket (A64194)
12 in. WRXLS...
John Deere 920 (A64126)
John Deere 920...
