Hydraulic Drive system.
/ Hydraulic Drive system. #21
If you are going to connect the pump shaft to shaft, the pump rotation needs to run opposite the rotation of the pump. The pump you selected turns CW, does the engine turn CCW?
/ Hydraulic Drive system. #22
Not sure what direction the motors turns, but I suspect most Briggs and Stratton would operate the same? I will definately spin it a few revs with the starter to see, before fabricating mounts. Note that my pump was originally designed for dual belt drive so that is the way I will be attaching it. I will also be using a 2:1 gear reduction, 3300 engine RPM to 1650 pump RPM.
/ Hydraulic Drive system. #24
Thats a cool machine. My machines primary purpose will be to carry sand so it will be somewhat heavier and likey much slower then the commercial one.
John Deere ZTrak Pro Series Z994R Operators Manual (A63117)
John Deere ZTrak...
LMC Ag 400 Gal Front Mounted Tank (A64119)
LMC Ag 400 Gal...
Great Plains Ultra Till 3030 (A63688)
Great Plains Ultra...
2015 KOMATSU PC360LC-11 EXCAVATOR (A64279)
2015 KOMATSU...
2017 Forest River Rockwood Freedom Camping S/A Trailer (A61574)
2017 Forest River...
2007 Cadillac DTS Sedan (A61574)
2007 Cadillac DTS...
