hydralic winch/crane trailer
/ hydralic winch/crane trailer #1
Deereman4020
Horicon Wi
1952 Oliver 77, John deere 7410
Hello im thinking of building a winch/crane trailer out of a grinder/mixer trailer/frame thing i would use a 12000# hydralic winch i just want some opinions on my idea
thanks Deereman
/ hydralic winch/crane trailer #2
I have built one. I did put the winch on the tractor and built an arch to pull behind it though. The arch doubled as a trailer as the arch part would lay down on the lower frame so I could pin the bed on.
if you are putting the hyd winch on the arch it should work just fine. I would check my hyd output of the tractor with the needs of the winch though. It will most likely be a bit slow.
If you are doing much with the arch on rough terrain, especially pulling downhill, you might consider putting electric brakes on the arch to keep it from pushing you down a hill or jacknifing you. Put the arch fairlead ahead of the tires somewhat to give some of the weight to the tractor. If it is straight above the trailer wheels it will tend to want to tip back and lift the tractor as you get in a hard pull.
One thing more, put a 360 degree swivel on the tongue, you will turn it over and no use in bending metal or breaking a drawbar.
Good luck on your project
thanks i plan on using the oliver 77 for the hydralics or maybe the johndeere 7410 i plan ion building the arch out of rectangular tubing and then weld it to the trailer frame with a block on top of the arch
NEW Wolverine GB-11-72W Skid Steer Grapple Bucket (A62679)
NEW Wolverine...
2022 EZ-GO ELITE...
2016 INTERNATIONAL 7400 TREATER TRUCK (A65643)
2016 INTERNATIONAL...
CHANDLER 500 BBL FRAC TANK (A65643)
CHANDLER 500 BBL...
Paladin 12in Bucket w/ Teeth Excavator Attachment (A64194)
Paladin 12in...
Lonestar Panel (4) 24ft. Free Standing Panels (A65640)
Lonestar Panel (4)...
