Hydralic Trouble
   / Hydralic Trouble #1
waynet17
wa state
kubota b7800 w/BH 4672a
Pulled the B7800 out yesterday to do maintenance. While extending the upper arm on the BH, the control lever was extremely hard to push and pull. The lever stickes in the open or closed position, and will not return to neutral position without forcing. I don't remember doing anything out of the ordinary with the backhoe. It has worked great for any digging that I have done.
The hoe is a three point unit, with a selfcontained hydralic reservoir. Fluid is clear, and at the full point. All the other functions of the hoe work as exsectewd. Please help.
   / Hydralic Trouble #3
Does the lever feel free? Does the BH work normally when you move the lever to the position for the action you want? Look for interference points that might inhibit it moving.
larry
   / Hydralic Trouble
Thanks for the response. The lever is extremely tight. When activated , it does not return to the neutral position by itself. I have checked the valves, and there is no obstruction that I can see.
   / Hydralic Trouble
Are you asking me to repost my question in the hydralics section?
49" X 74" EXPANDED METAL RAMP GATE (A51247)
49" X 74" EXPANDED...
Peterbilt 377 Semi-Truck (A53472)
Peterbilt 377...
UNUSED FUTURE SB05 HYD BREAKER (A51248)
UNUSED FUTURE SB05...
1263 (A50490)
1263 (A50490)
2012 John Deere Gator HPX 4x4 Utility Cart (A51691)
2012 John Deere...
2020 BOBCAT T76 R-SERIES SKID STEER (A51246)
2020 BOBCAT T76...
