Hydralic Trouble
   / Hydralic Trouble #1
waynet17
wa state
kubota b7800 w/BH 4672a
Pulled the B7800 out yesterday to do maintenance. While extending the upper arm on the BH, the control lever was extremely hard to push and pull. The lever stickes in the open or closed position, and will not return to neutral position without forcing. I don't remember doing anything out of the ordinary with the backhoe. It has worked great for any digging that I have done.
The hoe is a three point unit, with a selfcontained hydralic reservoir. Fluid is clear, and at the full point. All the other functions of the hoe work as exsectewd. Please help.
   / Hydralic Trouble #3
Does the lever feel free? Does the BH work normally when you move the lever to the position for the action you want? Look for interference points that might inhibit it moving.
larry
   / Hydralic Trouble
Thanks for the response. The lever is extremely tight. When activated , it does not return to the neutral position by itself. I have checked the valves, and there is no obstruction that I can see.
   / Hydralic Trouble
Are you asking me to repost my question in the hydralics section?
UNUSED HURRICANE GALVANIZED METAL LIVESTOCK SHED (A51248)
UNUSED HURRICANE...
2018 CATERPILLAR 320 LONG REACH EXCAVATOR (A51246)
2018 CATERPILLAR...
2014 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A53472)
2014 Doyle Dry...
KMC 5610 LOT NUMBER 33 (A53084)
KMC 5610 LOT...
UNUSED LANDHERO MIG-140 WELDING MACHINE (A51248)
UNUSED LANDHERO...
4' X 8' X 1/8" THICK DIAMOND PLATE STEEL SHEETS (A51247)
4' X 8' X 1/8"...
