hydralic toplink
/ hydralic toplink #22
mboulais said:
I haven't read the OSHA reg's word for word, but I think they are misqouting a section about equipment that employees are required to go under or into to perform tasks, otherwise we would see the same hydraulic circuits on all tractor loaders and forklifts. I have never seen a loader with that circuit and I doubt forktrucks have it since I have heard of more than one incident in industry where a mechanic was crushed under the forks of the fork truck he was working on. .
In those cases, the DPOCV is built right into the spool. It protects everything except for the hose rupturing. Prince sells these types of spools for their SV valve and I know that Henro got those instead of purchasing cylinders with DPOCV. Incidentially, you see these type of spools a lot on heavy equipment.
/ hydralic toplink #23
DANOCHEESE said:
Surplus center just said it would be the end of april for a cylinder!!!!
What bore and stroke were you looking for?
/ hydralic toplink #25
Marcel,
It came across like you thought CCM was being underhanded. You are right that a home or landowner isn’t required to have check valves. Words don’t always come across in a post the way that I mean for them to. Even after I proof read a post before I post it, I still go in an edit it sometimes because it didn't come across the way it should have. Once in a while it will sound mean or hateful. I always try to get them changed before the edit time runs out. I think what he was trying to get a cross was that one of the reasons that they sell the type of cylinders that they do is because of their safety aspect. The drive-in bushings do work great and I would recommend them to anyone that needs a reducing bushing.
/ hydralic toplink #26
I had been kind of watching the 2" bore 10" stroke cylinder for a month now and noticed yesterday that there was only one left so I ordered it. If that is the bore and stroke you are looking for you could always jump up to a 2.5" bore, they have plenty of them in the 10 and 12" stroke and are just a few bucks more.
/ hydralic toplink #27
Thanks Dallas Lilly. The 2.5 bore should work fine for my DX 35. I need to measure again. My tractor will not be here for awhile so I need to measure the neighbors. or the dealer had a dx45 should be the same top link.
/ hydralic toplink #28
The CCM hydraulic toplinks and side links with double piloted check valves will arrive at CCM on Monday April 2. Please give us a day to check them in before you call and place your order. We will start taking orders Tuesday April 3. ALL sizes should be available.
Thank you for your patience and support.
Mark Carter
/ hydralic toplink #29
Why are these top links so hard to get????????????
/ hydralic toplink #30
Since April 07 we have received other shipments. We sell hundreds of hydraulic toplinks and side-links a year. Both units include the double piloted check valves and are OEM quality. There are plenty of the lower quality toplinks without the DPCV out there but we don't like selling them.
/ hydralic toplink #31
They aren't domestic and we have to wait for a new shipment from China or wherever they are built when the supplier is sold out. :(
/ hydralic toplink #32
They are not Chinese cylinders like TISCO, A&I & Gannon. Our hydraulic cylinders have DPCV and are OEM quality. Just ask our customers on TBN what they think of our quality. The USA MFG's wanted to sell us inferior cylinders at prices more than the prices we are selling the hydraulic cylinders to the public. The USA mfg's are not hungry and do not care about this market.
/ hydralic toplink #33
I have got $200 burning a hole in my pocket. Measured my toplink this evening. It is 21" - 32" Cat II. This is something that has been on my "want list" for a long time. I am thinking of calling CCM tomorrow morning first thing and getting one. From what I hear, it probably has the lowest cost:benefit ratio for anything you can add to your tractor. Kinda like a toothbar. I just hope they have them in stock while I'm in the buying mood!:D
/ hydralic toplink #34
Didn't say they were inferior or superior, just clarified why we have to wait. Got that information from previous posts of yours.
Where are your cylinders built??
Heard last week that the richest man in the world is no longer an American, he's Mexican. :(
/ hydralic toplink #35
JerryG said:
I don't know what bushing you used but Surplus Center has a perfect bushing for those cylinder. I installed two of them in my cylinder that I got from Surplus Center. They are driven in and stay in place. If anyone else does get a cylinder from SC, get the bushings from them also.
Surplus Center Item Detail
I would have much preferred to have a cylinder from CCM, but they didn't ever seem to have them in stock and I need a third arm now.
Jerry and others, how are you liking your surplus center cylinder. I have mixed feelings about mine. The drift does not bother me to much, I am moving my box blade top link position enough that the drift is not noticeable. The rotary cutter does not use the top link to hold it in position when mowing so it does not mater. What does bother me is when using box blade when not using draft control when you are really digging dirt or hit something hard the top link will collapse and come back, but not always where you had it to begin with. It will extend when pushing backwards.
I have not had time but when I get back from my elk hunt I am going to disconnect the quick connects from the control valve and see if the leakage is coming from the cylinder internally or if it is coming from the control valve. If it is coming from the control valve I was thinking of plumbing in one of these valves Surplus Center Item Detail
or one of these valves Surplus Center Item Detail
Or one of these valves
Does anybody know which valve would work better. I know that they will be inferior to the CCM valves.
I do not think that I would mount either one of those valves to the cylinder but plumb it in in a more convienent place.
/ hydralic toplink #36
Dallas,
The first and third links you posted are the kind to get. They are double pilot operated check valves. It appears the second link only locks one line. For your boxblade work, you'd want the lock up in both directions in case of forward or rearward dirt engaging work. It's a few bucks more, but the installation will be the same and it will give you lock up in both directions. I bulldoze in reverse a lot and needed both ways.
/ hydralic toplink #37
3RRL said:
Dallas,
Thanks,
When isolate the problem I will see if I need the check valve. I have a feeling that I do. They are quite bulky but other than a line bursting and lines bulging I do not see any reason why they have to be on the cylinder and can be any where after the control valve.
/ hydralic toplink #38
I have very little drift if any. They only thing that I don't like about the Surplus cylinder is that the ball on the cylinder end is to close to the cylinder. I have to put the cylinder in the top hole on the tractor to keep the cylinder from turning into the tractor bracket and cutting into the cylinder. I may at a later date, buy a cylinder from Mark.
/ hydralic toplink #39
I agree that is another down point.
/ hydralic toplink #40
Where'e the Mad Referee when ya need him!!!! I'll try to address this issue using what I learned from Mad.
What you have described is compression. You cannot compress or expand hydraulic fluid. The only thing that could be present in your system that would compress or expand is air. The only other thing that could cause this would be hoses so soft that they expand and shrink with pressure or a cylinder barrel that similarly changes shape. These last two are highly unlikely.
If your cylinder is leaking past the internal seals, it would not return at all. It would simply close or open until the pressure is reduced below the leak tolerance and then stay static in that position until excessive pressure were again introduced. Even a DPCV will not help if the cylinder is leaking internally. A DPCV prevents the exchange of fluid between one cylinder fitting and the other. Internal cylinder leaks do not create that situation. No fluid moves at the cylinder barrel fittings.
If your valve is leaking, it will act the same way I described above. The difference would be that the DPCV would prevent cylinder drift if it's caused by valve leaks.
So, sounds like you have air in your cylinder?? It won't take very much air. A thimble full of air in the cylinder or pressurized system would allow the cylinder to move considerably. And again, after the pressure was reduced, the cylinder would somewhat return to it's original position.
Usually a cylinder will purge itself without help just from use. But it's possible to create a system that won't allow the cylinder to do that. For example, if enough hydraulic fluid can be introduced to one hose of the cylinder to extend or collapse that cylinder to it's limit without pushing all the air out of the opposite hose into the open center of the valve, then that remaining air is trapped in the cylinder plumbing system. It will simply be pushed back into the barrel of the cylinder when fluid is introduced into the opposite hose. To fix this will require uncoupling one hose from the tractor, unscrew the coupler from the hose end to create an open end, then gently apply hydraulic pressure to the other hose using the valve. This will spit out whatever fluid and air that is on that side of the cylinder seals. After the cylinder has reached the end of it's travel, holding the open hose vertical, pour it full of fluid and reinstall the coupler.
Sorry for the ramble. Hopefully some of it will be helpful. :)
1993 Transcraft DTL140W2 38Ft 60 Ton Spread Axle Step Deck T/A Trailer (A64194)
1993 Transcraft...
2019 HINO 195 18FT 4X2 S/A REFRIGERATED BOX TRUCK (A67148)
2019 HINO 195 18FT...
(25) SHEETS OF 3/4"-4'x8' OSB (A65055)
(25) SHEETS OF...
T/A CO2 Tanker Trailer (A64194)
T/A CO2 Tanker...
2022 Mac Trailers 48ft. T/A Walking Floor Trailer (A64556)
2022 Mac Trailers...
UNUSED RAYTREE RMSG29-HYD STUMP GRINDER (A65055)
UNUSED RAYTREE...
