Hydo Question
   / Hydo Question #1
langlom1
JD 4600
#1. Runs faster in reverse than in forward. Getting worse?
#2. Have a pump whine, step on pedals fwd or rev will stop whine?
I have a 4600 compact tractor,
   / Hydo Question #2
Suggest moving this from the AG tractor section
   / Hydo Question #3
It would really help if you could express yourself better.
   / Hydo Question #4
Sounds like you have a pressure relief valve that is opening when you are stopped. that would indicate too much pressure on one side or the other. There should an open center valve that would allow the pump to dump back to the tank. Try checking your hoses to make sure they not swelled or crimped or blocked ( I've seen hoses that come apart on the inside and block fluid flow.
   / Hydo Question
Thanks, I will check it out.:thumbsup:
Milt
6" & 10" I BEAMS UP TO 40' LONG & MISC (A51247)
6" & 10" I BEAMS...
1997 GMC T7500 Dump Truck, VIN # 1GDJ7C1P2VJ505340 (A51573)
1997 GMC T7500...
2022 John Deere 8R 340 MFWD Tractor (A53342)
2022 John Deere 8R...
John Deere 6430 Side Arm Tractor (A51573)
John Deere 6430...
1988 BASSTRACKER 20' PONTOON BOAT (A51247)
1988 BASSTRACKER...
2025 New/Unused Wolverine Pallet Fork Extensions (A51573)
2025 New/Unused...
