hyd/trans fluid leek
/ hyd/trans fluid leek #1
groofish59
Springfield Oregon
Branson 3510 H
hello
branson 3510 H leaking from bottom of what I believe is called the range shift drive shaft case ,{ its the small mid case}.
there is a factory formed hole fluid leaks from.
My question is should there be a plug or bolt in it , has mine come out?
/ hyd/trans fluid leek #2
hello
View attachment 797908My question is should there be a plug or bolt in it , has mine come out?
To be honest I don’t know, but on some a small hole is left open so oil can get out and not build up if something goes wrong. Hopefully someone with more knowledge will chime in
/ hyd/trans fluid leek #3
My New Holland TC30 leaks out of an identical hole. I'm pretty sure the hole is supposed to be open.
2018 JOHN DEERE 650K LGP CRAWLER DOZER (A64279)
2018 JOHN DEERE...
UNUSED SDLANCH SDL2030GT-20' X 30' PREMIUM HEAVY (A64281)
UNUSED SDLANCH...
UNUSED WOLVERINE MSG-11-44W STUMPLE GRAPPLE (A64281)
UNUSED WOLVERINE...
2017 FREIGHTLINER CASCADIA 125 6X4 T/A DAY CAB TRUCK TRACTOR (A59908)
2017 FREIGHTLINER...
New/Unused Quick Attach Backhoe Attachment (A65583)
New/Unused Quick...
2012 Ford F350 Truck (A62679)
2012 Ford F350...
