hyd/trans fluid leek
/ hyd/trans fluid leek #1
groofish59
Springfield Oregon
Branson 3510 H
hello
branson 3510 H leaking from bottom of what I believe is called the range shift drive shaft case ,{ its the small mid case}.
there is a factory formed hole fluid leaks from.
My question is should there be a plug or bolt in it , has mine come out?
/ hyd/trans fluid leek #2
hello
View attachment 797908My question is should there be a plug or bolt in it , has mine come out?
To be honest I don’t know, but on some a small hole is left open so oil can get out and not build up if something goes wrong. Hopefully someone with more knowledge will chime in
/ hyd/trans fluid leek #3
My New Holland TC30 leaks out of an identical hole. I'm pretty sure the hole is supposed to be open.
2018 International WorkStar 7400 T/A Lely 4,500 Gallon Septic Wet Vacuum Truck (A61568)
2018 International...
THREE POINT ATTACHMENT (A58214)
THREE POINT...
2024 JOHN DEERE 325G SKID STEER (A62129)
2024 JOHN DEERE...
(4) 11-22.5 Pivot Tires & Wheels (A62177)
(4) 11-22.5 Pivot...
GRID SHAPED BUCKET FOR MINI EXCAVATOR (A58214)
GRID SHAPED BUCKET...
Kubota M125X (A60462)
