Hyd top link- add on or new?
/ Hyd top link- add on or new? #1
DDT
Platinum Member
Clay Center, Kansas
Kubota M6040/cab, BX25D, RTVX900
I had a JD4400. Now a new Kubota L5030, My hyd top link is about 8" too short. Should I add on the end or buy a new one. The clylinder is a 2 x 8.
/ Hyd top link- add on or new? #2
You could easily weld your new 8 inch end on the existing cylinder. However your cylinder will still be lacking 8" of total movement. If that doesn't restrict your needs then go for it.
/ Hyd top link- add on or new? #3
Check the difference in length extended and retracted of your OEM link. If you add on to what you have, you'll probably not have enough throw in your cylinder. I would buy a replacement cylinder that matched the retracted length of my OEM link and was pretty close to the extended length.
I need about 8" so I can add on. It has threads on the end that I have a eye welded to a nut with a jamb nut behind that. I just need another nut and pipe and a new eye. This way I can remove the end easy and use it for some thing eles. It is a regular 2x8 cylinder that I made work for the top link. I will post a pic when done.
2000 FORD F-550 XL SUPER DUTY DUALLY SERVICE TRUCK (A60430)
2000 FORD F-550 XL...
UNUSED WOLVERINE MPF-11-2500G MINI PALLET FORKS (A62131)
UNUSED WOLVERINE...
2006 Dodge Ram 1500 Pickup Truck (A61568)
2006 Dodge Ram...
UNUSED WOLVERINE GB-11-72W 72" HYD GRAPPLE BUCKET (A62131)
UNUSED WOLVERINE...
Genie S40 Boom Lift (A64047)
Genie S40 Boom...
UNUSED WOLVERINE RPR-12-72W 72" RIPPER (A62131)
UNUSED WOLVERINE...
